Izracunajte izdrzljivost motora, obrtaji i vek trajanja...
  • V-Tec
    • 30.06.2006
    • 1615
    • '89 Civic d16a6
    Re: 1998 Honda S2000
    Originalno postavljeno od gordi014
    1998 Honda S2000
    87.00mm × 84.00mm
    3.43 in × 3.31 in
    243.3 PS (240.0 bhp) (179 kW)
    @8300 rpm
    Cm=0.167x3.31x8300=4587.99 ft/min
    Very short life !
    Ovo mi nije jasno jer se za ovaj motor prica da je veoma dobro izbalansiran i pouzdan.
    P.S.
    Dacia Logan 1.6 mpi
    Prečnik x hod klipa (mm) 79,5x80,5
    Najveća snaga kW (kS) 64(90) @ 5500 o/min
    Najveći obrtni moment (Nm) 128 @ 3000 o/min
    80,5(hod klipa) x 5500(max o/min) / 30000 = 14,758 Dobro!
    X<17.77 dobro
    17.77<X<20.31 napregnut motor, potrebna dobra konstrukcija
    X>20.31 lose
    Na 6200 o/min(blokada) je 16,636
    shuto-expressway.com
      za ovaj motor
      posto si odabrao da ce se taj motor voziti po pravilu sa 8300 obrtaja, takvi su i rezultati.
      ali, retko ko ce voziti taj auto i taj motor sa 8300 obrtaja, osim u vrlo kratkim intervalima tokom menjanja brzina.
      po meni, logicnije je uzeti broj obrtaja motora za rezim voznje kakav je najcesci kod doticne osobe.
      obicno je to 2500-4000 obrtaja najcesci opseg broja obrtaja svakodnevne voznje, tj voznje u kontinuitetu vise sati.
      • X9
        • 28.06.2005
        • 3179
        • Wien-Sabac
        • RX-8 i X-9
        za moj motor:
        Mean Piston Speed
        - V6 Engines - all-alloy DOHC 24V 60-degree V6 configuration
        - Split Crankcase - as 911 flat-6 offers increased rigidity over traditional bearing-cap solutions for high-rpm capability (7800rpm 2.0V6) and low NVH (winning 1992 German engine award)
        - Bearings - 4-bolt Mains, with a further pair of bolts at each bearing section. Key journals & bearings are oversized regarding width. Bearings are triple-layer heavy duty
        - Crankshaft - Forged, nitrided, triple-lapped, mirror-finished
        - Piston Squirters - Upper bearing journals contain piston oil-squirters to aid cooling
        - Exhaust-Valves - Stainless steel & sodium cooled
        - Pistons - Lightweight to reduce reciprocating mass, piston skirts are moly coated to reduce friction
        - Head Gaskets - Stainless steel is used, with torque-to-yield bolts
        - Stroke - Very short stroke creates low crank angles & low rod/bearing loads
        Engine Dynamic Stress Levels
        o Mean Piston Speed, MPS
        - 2.5V6 MPS = 0.167 * 2.92 * 7000 = 3170 ft/min at 7000rpm
        o Ring Loadings
        Top-rings must balance high-rpm capability and wear, a thin ring allows high-rpm capability, too thin and wear becomes an issue. With reduced crank angles from a short stroke ring wear is reduced. A 1.5mm ring is beneficial over a 1.0mm ring for high-rpm.
        Maximum-Piston-Acceleration (MPA):
        2.5 top-ring - 1.49mm/0.06"
        - MPA Permitted = 77,000ft/sec^2
        - MPA Experienced = 51,354ft/sec^2 at 7000rpm
        - The BMW M5 in comparison experiences MPA of 90,000ft/sec^2 on a 1.5mm ring
        Lighter rings create reduced accelerative forces, reduced ring/piston interface overheating and reduced hammering of the piston-ring-groove. Too light and ring longevity is adversely affected
        2.5 rod-centre-dist = 138mm; stroke = 74.2mm; A = 1.87
        - MPS-2.5 = (7500^2*2.92/2189)*(1.2*1.87) = 70,157 ft/sec^2
        Both the 2.5V6 & 2.0I4 engines are engineered for longevity. The 2.5 engine is likely to be the longer lived engine subject to identical maintenance to the 2.0 engine. Mazda V6 engines are assembled entirely by robots, not humans, at the Osaka engine plant in Japan alongside Rotary engines.
        Ford bench testing, with very minor changes, showed the V6 to be capable of continuous running at 8900rpm - well beyond redline 7500rpm.
        SAE paper "SAE920677" covers detailed design of the engine.
        "After 300,950 miles the Mazda MX6-V6 passed an IM 240 Exhaust Emission Test in Aurora, Colorado, with results well within new car limits. At more than 310,000 miles, the test engine was disassembled for inspection and measurement. No wear was evident on valve stems and guides, main and rod bearings, crankshaft main and rod journals, or cylinder walls. The cylinder hone marks from original factory machining were all clearly evident. While piston skirts showed no wear, piston rings showed an average of only 0.0015" of face wear."
        over and out
        No ROTOR no MOTOR...
        • Damjan156
          • 07.01.2008
          • 568
          Evo šta meni kaže:Alfa Romeo 156 2.0TS 99-o godište
          83x91mm
          3.27x3.58 in
          155.1 PS (153.0 bhp) 114.1kW @6400
          cm=0.167 x L x N
          cm=0.167 x 3.58 x 6400@
          cm=3826 ft/min
          a blokada na 7500@ onda izgleda ovako 4487 ft/min
          LUDILO! A jos sledi chip tuning,he,he!
          Strauli motorsport
          Moja Alfa
          NIŠTA NIJE TVRDOGLAVIJE OD EMOCIJE
          • siki
            • 05.03.2009
            • 46
            • Kruševac
            Re: Izracunajte izdrzljivost motora, obrtaji i vek trajanja...
            Da vidimo jeli moja računica tačna:84.00 mm × 90.00 mm
            3.31 in × 3.54 in onda idemo: 0,167 x 3,54 x 5600=3.310 jel to dobro
            ako ga žešće vrtim na 6000 o/min onda je rezultat 3.547 .molim komentar onoga koje pustio formulu.
            Inače u pitanju je motor od 2.0 lit 4 cil 16 ventila turbo 2 litre
            1995 cc
            (121.742 cu in)207.8 PS (205.0 bhp) (152.9 kW)
            @ 5600 rpm
            Specific output 102.8 bhp/litre
            1.68 bhp/cu in
            Maximum torque
            (DIN) 298.0 Nm (220 ft·lb) (30.4 kgm)
            @ 2750 rpm
            bmep 1877.1 kPa (272.2 psi)
            Specific torque 149.37 Nm/litre
            • kilson
              • 3216
              • NoviBGD
              • AR 75 GT
              nder 3,500 ft/min Good reliability
              3,500-4,000 ft/min Stressful, needs good design
              Over 4,000 ft/min Very short life
              Sta ti nije jasno u celoj prici? Losi rezultati kazu da motore dugog hoda ne treba siliti sa "navrtanjem" po crvenom polju zbog velike brzine klipa. Sto se tebe tice, miran si i na 6000 rpm, ali ne znam sta ce ti 6000 rpm obzirom da vozis fabricki FI motor.
              • siki
                • 05.03.2009
                • 46
                • Kruševac
                Hvala lepo Kilsone ,malo sam brinuo jer volim da opalim po gasu-normalno na autoputu-Znači izračun je tačan ako se ne varam po tvom odgovoru,a šta ti znači FI motor
                i ako nije tajna ono ispod koji je bio auto na 7000 o/min.
                • kilson
                  • 3216
                  • NoviBGD
                  • AR 75 GT
                  FI - forced induction Samo ti uredno odrzavaj tu makinu i nema problema.
                  [off] Ovo 7000 rpm je interna fora u vezi prenosnih odnosa na jednoj matoroj drtini...
                  • Raverick
                    • 02.07.2008
                    • 21
                    • Cuk.Padina-Mladenovac
                    Fiat Ritmo 105 TC
                    1.6 DOHC 8v-77kW
                    84x71.5mm
                    3.31x2.81in
                    105bhp@6100rpm
                    0.167x2.81x6100=2862,547 ft/min
                    Good reliability
                    The world is yours if you can handle..
                    • charjek
                      • 20.09.2008
                      • 191
                      • Sremska Mitrovica
                      • Jugo
                      ajd sad ovako ko zna da izracuna
                      Skoda 120 LS 1980god hod klipa 72/72
                      43 kw
                      i sta vam jos treba,jer koliki obrtni je momenat nemam pojma
                      ajd vidim ja moju taljigu kakva je
                      Zene su zakon, a muskarci uvek traze rupu u zakonu!!!
                      • nikolicji
                        • 27.06.2007
                        • 133
                        Honda prelude 1986 1.8 dualcarb 80x91
                        @4000 rpm (max torque 155 Nm) 12.133 m/s
                        @5500 rpm (max power 107.5 PS) 16.683 m/s
                        @6200 rpm (redline start) 18.807 m/s
                        @8000 rpm (max mark teoretski) 24.267 m/s
                        Lud za Prelude
                        • senzacija
                          Renault Clio RN 1.4 Energy
                          75.80mm x 77mm (2.98in x 3.03in)
                          81.1 PS (80 bhp) (59.7 kW) pri 5750 rpm
                          Cm=0.167x3.03x5750=2910 ft/min
                          Good reliability
                          • cedo86
                            • 20.12.2009
                            • 14
                            Ford Mondeo Mk3 2.0 TDCi
                            86 x 86mm ili 3.39 x 3.39in
                            96kW@ 3500o/min
                            Cm=0.167x3.39x3500 =1981ft/min ili 10.1m/sec
                            • YUgisa
                              • 05.06.2008
                              • 935
                              • Subotica
                              • Yugo 1.3EFI Stroker
                              S=hod klipa (eng. stroke)[mm]
                              B=max. br. obrtaja u minuti (rpm)[o/min]
                              X=brzina klipa[m/s]
                              X=S*B/30.000
                              Pa sad:
                              X<17.77 dobro
                              X>20.31 lose
                              Yugo 1.1 i 1.3 Hod 55.5 mm
                              X=55.5x9500/30.000
                              X=17.575
                              • Desmo
                                • 27.06.2010
                                • 280
                                • Vrsac
                                • VW Mk2 1.8
                                Mislim da grešite u računanju kod obrtaja, u formuli se za broj obrtaja uzima vrednost "factory redline" - maksimalni broja obrtaja.
                                Broj obrtaja na kojim motor isporučuje najviše snage je manji od maksimalnog broja obrtaja.
                                Aspirazione naturale!
