sa olympus c 350 digitalcem, kakvog i ja ima, slika je do * cenzura_ovde nediskutujemo pijachne poslastice_cenzura *, i lice mi se vidi, digitalac je namesten da laser....
To se ti zezas?
Pa jel se vidi na toj slici i brzina?
Model C-350 ZOOM
Type Digital camera with 4.5cm/1.8 inch colour TFT LCD monitor.
Image sensor
Image sensor 1/2.5 inch CCD solid-state image pickup with 3.3 million pixels.
Effective pixel number 3.2 million pixels. (The actual number of pixels used in image
processing.)
Filter array Primary colour filter (RGB).
Media
Storage media type Removable xD-Picture Card (16, 32, 64, 128 and
56MB).
Lens
Optical zoom 3x
Structure 5 lenses in 3 groups. 3 aspherical lens elements.
Focal length 5.8 ? 17.4 mm(equivalent to 35 -105 mm lens in 35 mm format).
Maximum aperture F3.1 (Wide) / F5.2(Tele).
Digital Zoom 3.3x seamless.
Viewfinder Optical real-image.
LCD monitor 1.8 inch colour TFT LCD monitor with 85,000 pixels.
Focusing
System TTL system iESP auto focus with contrast detection.
Mode Auto iESP autofocus.
Working range Standard mode 0.5 m ? infinity.
Macro mode 0.2 m ? 0.5 m
Light metering
Mode Digital ESP metering,
Spot metering.
Function AE lock (with 1st shutter release).
Exposure
Exposure control Program AE.
Scene Programs (Portrait, Self-portrait, Night Scene, Landscape).
Shutter speed 2 ? 1/1000 sec.
Compensation ?2 EV in 1/2 EV steps.
Sensitivity
Auto ISO 64-400.
White balance
Mode Auto iESP auto.
Preset Sunlight, overcast, tungsten light, fluorescent light.
Flash
Built-in flash Modes Auto (automatic activation in low and backlight),
Red-eye Reduction,
Fill-in (forced activation).
Slow synchronisation
(Only with night scene mode in Scene Select:
First-curtain synchronisation effect,
First-curtain synchronisation effect with red-eye reduction),
Off (no flash).
Working range Wide: 0.2 ? 3.4m, tele: 0.2 ? 2.0m.
Recycle time Approx. 6 sec.
Guide Number 7.6.
Sequence shooting 1.5 fps.
Processing
Image processing True Pic, pixel mapping, noise reduction in night scene mode.
Function shooting 2 in 1, panorama.
Editing
Still image edit Re-size, rotation, sepia mode, black & white mode.
Motion picture edit Index.
Recording System
Still image JPEG (DCF: "Design rule for Camera File system"), Exif 2.2 support,
Print Image Matching II support, DPOF support.
Motion picture QuickTime Motion JPEG?*.
Number of storable frames (Approx., with 16MB xD-picture Card)
Still picture mode 2048 x 1536 SHQ approx. 6 images.
HQ approx. 20 images.
1,024 x 768 SQ1 approx. 76 images.
640 x 480 SQ2 approx. 165 images.
Motion picture mode SHQ (320 x 240 pixels): Up to approx. 48 sec. (15 frames/sec.)
HQ (160 x 120 pixels): Up to approx. 211 sec. (15 frames /sec.)
Power supply
Rechargeable battery 2 x AA Ni-MH rechargeable batteries.
One time use battery 1 x lithium batteries LB-01(CR-V3),
2 x AA alkaline batteries,
(* zinc carbon (manganese) batteries cannot be used).
AC Adapter Optional AC adapter C-3AC;
AC 100V-240V, 50-60Hz; DC 3,3V and 3A
Interface DC input terminal,
USB Auto Connect interface (storage class),
Video output terminal.
Other features
DPOF setting Single-frame print reservation, all print reservation, number of prints,
Date/Time display, cropping.
Multilingual menu English / French / German / Spanish.
Setting memorisation Yes.
Self-timer Yes.
Date/time/calendar system Up to year 2099.
Size
Dimensions 108 (W) x 57.5 (H) x 40 (D) mm (excluding protrusions).
Weight 170g (without batteries and xD-Picture Card).
Box contents Strap, 16MB xD-Picture Card, USB cable, video cable,
two AA alkaline-manganese batteries,
CAMEDIA Master 4.1.
Ma naravno da je ne moguce.Tablice na nekoj udaljenosti(znaci bas iz daljine bi mogle da se snime uz neki objektiv reda 300mm zizne daljine,uparen na neku spravu od soma eur minimum(objektiv taj o kom pricam je red velicine jedno 3 puta skuplji od fotoaparata profi klase(samo telo)).
A to nasi murijaci sigurno nemaju,posto bi onda stvarno licili na profi fotografe na nekom photo sessionu nego na pandure.
ma ljudi kazem Vam da je ta oznaka gledao sam, zumira onako srednje, auto se super vidi, kao i tablice, steta sto mu nisam trazio da mi otstampa!!
Nisu oni sa neke udaljenosti me hvatali, max 30-50 m , jedva sam i ukocio
Ma nemoj reci da imaju i stampac?
Mene kad su uhvatili na radaru je pisala udaljenost 470m (ljubazni pandur mi objasnio sta je sta), na toj udaljenosti ne mogu nikako da vide tablice
Danas su me ufackali na ulazu u Novi Sad... Pokazali mi slicicu na kojoj je moj auto i pise crvenim slovima 74, a kzu da je ogranicenje 60, a nigde znaka nema.... OK, kao grad, i im 2 take pa 60 ogranicenje, a ja se pitam kako onda kod sajma u bg ili bilo kom delu Novog Beograda nikad tako ne zaustavljaju.... Prosao sam sa 1000 din manjka.....
Ne voziš dovoljno
Kod Sajma redovno 2-3 patrole, a na NBG ?uveni beli golf u Jurija Gagarina.
kako su glupi,taj golf je provaljen pre 4 godine . Sad,kad pocnu vrucine,fora im je da se nameste ispod drvetak,kaje stoje uz put,pa samo pecaju. Pazte, usporavajte kad vidite bilo kakvo drvo,sto pravi 'ladovinu
