promena dimenzije i fabricka dimenzija
  • zec
    • 05.01.2005
    • 450
    • bgd
    gde mogu da saznam koja je fabricka dimenzija gume za seat ibiza 1.5 sxi 1991 god? da li neko zna?
    trenutno su 185/60 r 14 5.5j
    a ja bih presao na 155/80 r 13 za zimu
  • Wiz
    • 3104
    • Nish
    Dobar izbor za zimu samo napred
    • Wartburg
      • 01.02.2005
      • 663
      1985 Seat Ibiza 1.5 GLX
      Bodywork
      Type: 4/5S HBK
      Number of doors: 3
      Dimensions
      Wheelbase: 2448 mm 96.37 in
      Track front: 1420 mm 55.90 in
      Track rear: 1405 mm 55.31 in
      Length: 3638 mm 143.22 in
      Width: 1608 mm 63.30 in
      Kerb weight: 888 kg 1957.70 lb
      Fuel capacity: 50 l 13.20 US gal
      Ein kleiner Großer für dick und dünn
      (Wieder) ganz vorne?
      Geht diese Formel auf?
      Read the latest automotive news on http://www.globalcarnews.com
      Brought to you by Lake City Export
      Engine
      Type: S-4
      Wet sumped
      SOHC
      8 valves total
      2 valves per cylinder
      Main bearings: 5
      Bore x stroke: 83.00mm × 67.50mm
      Bore / stroke ratio: 1.23
      Displacement: 1461 cc 89.15 cu in
      Compression: 10.50:1
      Fuel system: 1 We 22 DSTA 100 carb
      Aspiration: Normal
      Catalytic Converter: N
      Max. output: 84.2 PS (83.0 bhp) (61.9 kW)@5600 rpm
      Max. torque: 116.0 Nm (86 lbft) (11.8 kgm)@3500 rpm
      Max. rpm: 6000
      Coolant: Water
      Specific output: 56.8 bhp/litre
      Specific torque: 79.4 Nm/litre
      Performance
      0-60mph: 10.9 s
      Quarter mile: 17.70s
      Top speed: 172 km/h
      Power to weight: 93.47 bhp/ton
      Chasis
      Engine location: Front
      Engine alignment: Transverse
      Steering: rack & pinion
      Turns lock-to-lock: 3.500
      Suspension front: I.MS.ARB.
      Suspension rear: I.LW.TL.
      Wheels F/R: 5.0 x 13/5.0 x 13
      Tyres front: 155 SR 13
      Tyres rear: 155 Sr 13
      Brakes: Di/Dr-S
      Transmission: 5M
      Drive: FWD
      Top gear ratio: 0.77
      Final drive ratio: 3.74
      Ovo sam nasao.
      Nadam se da je od neke pomoci.
      Poz!
      • zec
        • 05.01.2005
        • 450
        • bgd
        hvala puno.
        nalazio sam na nekim ibizama 185/65 r 14 a negde sam procitao da treba 185/ 60 r14 ali nisam bio siguran.
        verujem da je 155/80 r 13 = 155 r 13
        • Wartburg
          • 01.02.2005
          • 663
          Nema na cemu!
          Poz!
