gde mogu da saznam koja je fabricka dimenzija gume za seat ibiza 1.5 sxi 1991 god? da li neko zna?
trenutno su 185/60 r 14 5.5j
a ja bih presao na 155/80 r 13 za zimu
1985 Seat Ibiza 1.5 GLX
Bodywork
Type: 4/5S HBK
Number of doors: 3
Dimensions
Wheelbase: 2448 mm 96.37 in
Track front: 1420 mm 55.90 in
Track rear: 1405 mm 55.31 in
Length: 3638 mm 143.22 in
Width: 1608 mm 63.30 in
Kerb weight: 888 kg 1957.70 lb
Fuel capacity: 50 l 13.20 US gal
Ein kleiner Großer für dick und dünn
(Wieder) ganz vorne?
Geht diese Formel auf?
Read the latest automotive news on http://www.globalcarnews.com
Brought to you by Lake City Export
Engine
Type: S-4
Wet sumped
SOHC
8 valves total
2 valves per cylinder
Main bearings: 5
Bore x stroke: 83.00mm × 67.50mm
Bore / stroke ratio: 1.23
Displacement: 1461 cc 89.15 cu in
Compression: 10.50:1
Fuel system: 1 We 22 DSTA 100 carb
Aspiration: Normal
Catalytic Converter: N
Max. output: 84.2 PS (83.0 bhp) (61.9 kW)@5600 rpm
Max. torque: 116.0 Nm (86 lbft) (11.8 kgm)@3500 rpm
Max. rpm: 6000
Coolant: Water
Specific output: 56.8 bhp/litre
Specific torque: 79.4 Nm/litre
Performance
0-60mph: 10.9 s
Quarter mile: 17.70s
Top speed: 172 km/h
Power to weight: 93.47 bhp/ton
Chasis
Engine location: Front
Engine alignment: Transverse
Steering: rack & pinion
Turns lock-to-lock: 3.500
Suspension front: I.MS.ARB.
Suspension rear: I.LW.TL.
Wheels F/R: 5.0 x 13/5.0 x 13 Tyres front: 155 SR 13
Tyres rear: 155 Sr 13
Brakes: Di/Dr-S
Transmission: 5M
Drive: FWD
Top gear ratio: 0.77
Final drive ratio: 3.74
Ovo sam nasao.
Nadam se da je od neke pomoci.
Poz!
hvala puno.
nalazio sam na nekim ibizama 185/65 r 14 a negde sam procitao da treba 185/ 60 r14 ali nisam bio siguran.
verujem da je 155/80 r 13 = 155 r 13
