tecnost za ciscenje dizni ...
  • Jesa
    • 23.03.2008
    • 344
    • Honda Civic 1.4 LS
    Re: tecnost za ciscenje dizni ...
    E nasao sam odlicno sredstvo, ali ozbiljno!
    Sipao sam pun rezervoar Shell V-Power Racing, u Madjarskoj i malo priheftao papucicu za gas na autoputu
    CRX-u se mnoooogo svidela `jaca` corbica
    www.reverbnation.com/eclipsebgd
    • IlijaGM
      • 02.12.2008
      • 313
      • Gornji Milanovac
      Originalno postavljeno od alexa05
      Wynns! Ima posebno za benzince, posebno za dizelase, posebno za ovo, posebno za ono... Kod mene lepo odradilo posao!
      jel moze neka skika tog aditiva za dizele(za ove nove motore common reil),nacin koirishcenja...
      nemci i nemacki automobili postadose ko Čak Noris... sve su oni..
      • alexa05
        • 23.07.2006
        • 1777
        • Opel Vectra B 2.0DI 16v
        Ilija brate, nisam sacuvao ambalazu ali planiram, ovih dana kad se zaputim put Zlatibora da ponovim tretman. Ajde slikacu bocicu pa ti postavim sliku ovde.
        • alexa05
          • 23.07.2006
          • 1777
          Injector Cleaner for Diesel Engines is a treatment, which increases engine performance, reduces black smoke and improves MPG.
          Ref. Nr. 51668 – 325 ml
          Properties
          * Cleans injectors and restores spray pattern.
          * Improves the ignition quality and combustion of diesel fuel.
          * Facilitates cold starting.
          * Reduces diesel knocking noises and soot particulates.
          * Reduces black exhaust smoke.
          * Cleans and protects the entire fuel system against rust and corrosion.
          * Lubricates pumps and injectors and compensates for the reduced lubrication of low sulphur diesel.
          * Prevents fouling of the fuel filter.
          Applications
          * Recommended for all diesel engines with or without turbocharger.
          * In case of diesel knocking, difficult starting, too much black exhaust smoke, poor functioning of pump and injectors, high fuel consumption.
          Directions
          * Add Wynn's Injector Cleaner For Diesel Engines to the diesel fuel tank, preferably before filling-up.
          * Normal dose : 1 bottle of 325 ml every 4.000 km (2.500 miles).
          * In case of fouled injectors or too much black exhaust smoke: 1 bottle the first 3 tank fillings, then continue with normal dose.
          Da ne bi cekao evo ti sa njihovog zvanicnog sajta informacije o proizvodu koji sam ja koristio. Drago mi je ako sam ti bar malo pomogao Ilija.
            ja sam sipao na pun rezervoar evrodizela koji sam sipao na OMV ovaj aditiv: http://www.wynns.be/product.aspx?nav=1& ... 51668&l=EN
            i dimljenje na auspuhu kod ubrzanja i patosiranja pedale se drastichno smanjilo ,skoro da ga nema.
            ja sam kupio ovaj aditiv na OMV pumpi,kostao je oko 550 dinara.
            meni je pomoglo,primetilo se poboljshanje posle nekih 50ak predjenih km po gradu.
            lakshe paljenje,mirniji rad i mnoogo manje dima na auspuhu kod "patosiranja" pedale.
            i evo posle vishe od 5000 predjenih KM i dalje je sve OK ,ali sipatju ponovo ovih dana isti aditiv.
            inache ja sam sipao celu tu bochicu na pun rezervoar Evrodizela .. 45 litara.
            • zverko
              • 19.08.2005
              • 7084
              ljudi, ne zanosite se i ne bacajte pare. ako vec necete da radite ultrazvucno pranje javite se coveku sa foruma sa nickom Nagata. covek radi winns metodu daleko ispod cene koju bi ste platili u servisu.
              • alexa05
                • 23.07.2006
                • 1777
                Thanks for the info!
                • Puzo81
                  • 04.08.2009
                  • 687
                  • Novi Sad/Prijepolje
                  Aditivi tipa Sonax,Wynns,LM itd pomazu al max na 4-5000.
                  Wynn's ceo tretman je extra al posle 7-10 000 mora da se ponovi, to govorim iz licnog iskustva.E sad mozda oni "majstori u MVM-u" nisu dozirali aditiva koliko treba u tom procesu od sat vremena pa su se prvobitni efekti izgubili posle samo 8000km.
                  Ako ima neko iskustva s ultrazvucnim ciscenjem il Wynn's tretmanom nek napise svoja zapazanja?
                  • alexa05
                    • 23.07.2006
                    • 1777
                    Originalno postavljeno od zopu81
                    To i pise na uputstvu za Wynns aditiv koji sam ja koristio.
                    • Puzo81
                      • 04.08.2009
                      • 687
                      NE CITIRAJ POST IZNAD
                      Ce da probam i taj sto si sipao pa javim rezultat
                      • IlijaGM
                        • 02.12.2008
                        • 313
                        • Gornji Milanovac
                        Hvala Alexi i Zoranu pomogli su mi puno.Evo znaci i ja sipam za neki dan pun rezervar+aditiv shto ste mi rekli,pa cemo da vidimo kakvi ce rezultati da budu.
                        • alexa05
                          • 23.07.2006
                          • 1777
                          U svako doba Ilija!
                          Jedino sto sam hteo da dodam je da znam par ljudi koji su koristili slicne stvarcice tipa Abro, STP i sl ali na 1/2 rezervoara i nisu imali nikakvih problema sto nije ispostovano uputstvo za "full tank". E sad na tebi je da odlucis, ja sam samo preneo tudja iskustva.
                          • zverko
                            • 19.08.2005
                            • 7084
                            ja sam svasta nesto sipao u rezervoar. nista, klasican placebo efekt. bio kod nagate na winns... nako, bilo je razlike ali ne drasticne. skinuo dizne i ultrazvucna kadica, izaslo garezi sacuvaj boze... od tad presao preko 30000 i evo opet je poceo da zeza na leru i da guta knedlu kad je hladan a bogami sve cesce i kad je vruc. znaci mora ponovo na pranje jer nam je chorba u poslenje vreme katastrofa i mislim da nikad gora nije bila pa cak i u vreme kad smo sipali svasta na kantu. znaci, probajte kod nagate da uradite winns ako ne budete zadovoljni, skidanje i kadica. U svakom slucaju, winnsom se moze odrzavati stanje redovnim tako sto cete bar jednom godisnje odraditi ciscenje ili jos bolje svakih 10000 uz mali servis ili da na svaki pun tank dodate bocu nekog aditiva i tako sprecite stvaranje taloga u brizgacima.
                            • nikaragva
                              • 03.06.2008
                              • 521
                              • B. Palanka
                              • Opel Astra h 1.9CDTI 16V
                              Uh, meni bi svaki pun tank znacilo svakih 5 dana Odose sve pare na auto
                              • Čiča
                                • 14.12.2005
                                • 1621
                                • Beograd, Vidikovac
                                Originalno postavljeno od IlijaGM
                                Ilija, meni su rekli kada sam kupioo auto da svako drugo ili trece sipanje goriva dodam Wutrh-ov CR aditiv (common rail) za dizele.
                                Ni sam ne znam da li je bolje ili ne, ali ja to praktijujem. Jednom nisam mogao da nadjem aditiv mesec dana, sipao 4-5 puta gorivo, kada sam sledeci put dodao aditiv, motor je radio mirnije i startovao je "lakse"
                                Ovo sve moze da bude subjektivan osecaj. Da nam je gorivo njesra to je vise nego ocigledno ( cak se slazem da mislim da je bilo bolje kada smo sipali na ulicama ), pa stoga ovi aditivi ne mogu da skode, ali ne verujem da mogu da preuprede sve probleme.
                                Ko je viknuo "šta vidis ČičA"???
                                Sreća je sto glupost ne boli, inače bi sa svih strana odjekivali jauci
                                "Ulažite u stomak! To ulaganje daje brze i vidljive rezultate. Ulaganje u glavu je dugotrajno i neizvesno. " D. Radovic
