Laguna II 1.8 16v , 2000 obrtaja ???
  • blackR
    • 03.08.2010
    • 12
    • Krusevac
    Re: Laguna II 1.8 16v , 2000 obrtaja ???
    ^ pritiske je moj prijatelj koji radi klime ispitao i rekao da je sve u redu. mada se ja u to ne razumem puno, te da nije sada na odmoru bas bih ga konkretno pitao sta je radio, te citirao ovde ...
    U svakom slucaju prenecu mu ovo sto si napisao kada se vrati. Interesuje me dali moze da bude mozda ovo, tj. dali je to to ... citiram odgovor koji sam dobio na reno forumu :
    "Drugi odgovor je mnogo opasniji (skuplji) ali čini mi se da dolazi od tehnički potkovanijeg čoveka:
    "So, on my car it works like this: The ECC-unit (the AC-panel on the dash, with the buttons and display) will send a signal to energize an electromagnetic valve placed on the compressor if engine speed is above 2300rpm. The signal is reset when rpm falls below 2000rpm. When the signal is active the electromagnetic valve opens and makes a bypass in the refrigerant circuit, and by doing so, the capacity of the compressor will decrease. Since the rpm is above 2000, the cooling capacity still will be enough.
    The faults on my car: No cooling above 2300rpm, the compressor clutch simply disengaged over 2300rpm. The car had set the faultcode DF030 which means error in the "variable capacity" function. The workshop manual suggests to measure the resistance over the coil in the solenoid to the electromagnetic valve. If resistance isn't 18,5 +-0,5Ohms, the compressor should be replaced. My car measured about 2 ohms.
    The compressor was replaced on my car but the same fault still existed. The shop then replaced the ECC-unit, and then it worked.
    Reason for this is that when resistance in the coil changes from 18 to 2 ohms, the current in this circuit will increase from about 0,7 to 6 Amps. The circuit has a 20Amp fuse (also feeds the magnetic clutch). This abnormal current fries the electronics in the ECC-unit. Therefore, the ECC-unit has to be replaced aswell. So the failure of the ECC-unit is a secondary fault caused by the failing solenoid coil.
    We have investigated this error quite alot and you can read about it in forums in at least Sweden, Norway, France, UK and Holland. But no official acknowledgement from Renault.."
    Suština je da naše klime imaju funkciju varijabilnog kapaciteta tj da iznad 2300rpm se njihov kapacitet smanjuje tako što elektromagnetni ventil koji je jna kompresoru tada dobija signal i premošćuje (bypass in the refrigerant circuit) rashladno kolo, ali kako (kod njega) otpor na namotaju tog ventila iznosi samo 2 oma (umesto propisanih 18,5) to će reći i da je struja u njegovom kolu umesto 0,7A čak 6A što je moguće jer je osigurač od 20A. Ovolika struja je spalila kolo u ECC-u (tj cela upravljačka jedinica klime u kabini - ono sa displejom (ko ima dvozonsku klimu) i dugmićima iznad pepeljare) što je značilo da je on rešio problem tek kada je zamenio i kompresor i ECC!?"
    • aivan
      • 28.02.2006
      • 247
      • Bograd, Mirijevo
      Sve deluje logicno (nazalost).
      Jesi li probao kod sebe da izmeris taj otpor?
      Astra Classic II 1.4 Twinport (ex: Kadett E 1.3i )
      • blackR
        • 03.08.2010
        • 12
        • Krusevac
        ^ nisam, ovih dana cu. Javljam
        • majstorbob80
          • 13.05.2008
          • 184
          • 735E32, 525E39 Mlook
          Na dijagnostici imas opciju pracenja visokog pritiska, isprati nju, moguce je da ti pritisak luduje pa zato iskljucuje kompresor, a postoji mogucnost da presostat laze ecu pa ovaj iskljucuje spulnu na vecim obrtajima.
          Čovek se uči dok god je živ!!
          • blackR
            • 03.08.2010
            • 12
            • Krusevac
            ljudi jel to TO ?
            ... evo na uk forumu cini mi se konacnog resenja ...
            citat: "Allright the problem is now sorted!!!!!!!
            After having the compresoor changed 3 times (once by a local shop in Denmark, once at a Renault dealer in Germany and once by a Renault dealer in France) there was still no solution.. But they were great at the dealer in Dole, France.. Despite the language problems, they were very keen to find the problem. So they changed the compressor under warranty, but with no succes. Then they checked all the diagnostics and other electrical wiring, but with no luck again. Then they wrote to the main Renault Center i Paris for an answer. They didn't have any answer either, but advised the shop to check the heater control panel. But my parents had to head back to Denmark, so they didn't check it out. He paid 60 Euros for 3 days of labour, so that was quite allright.. Back home in Denmark, my dad went to see a friend, who's an auto electro mechanic. He checked the (french) internet and found that the fault was in the circuit board in the Heater Control Panel, but that Renault would not recocnize the fault So he took out the panel and found it to be "burned" even though no direct fault were to detect in function. He ordered a new panel and BING, now it works perfectly. But it will probably malfunction again in some years, so then one will have to replace it again.
            But to all you guys with that problem: Change the panel and job done!!
            Good luck!!"
            http://www.renaultforums.co.uk/showthre ... post660242
            Sta raditi ? Koliko moze da kosta ? Nisam bas razumeo koji panel treba zameniti ?
            • DRAGANFORD
              • 18.02.2009
              • 103
              Da li ste gledali koja je količina energije apsorbovana uključivanjem kompresora? kojim se to uredjajem meri?
              • blackR
                • 03.08.2010
                • 12
                • Krusevac
                ^ nisam, niti znam cime se meri. Dogovarao sam se sa Gavrom, bio sam u medjuvremenu u Bg, ali mi je bila stiska sa vremenom, pa ne kontaktirah coveka.
                Dali mislis da oko toga moze nesto da bude ?
                • zokce
                  • 06.05.2008
                  • 26
                  • Leskovac
                  • Renault Laguna II 1,8 16V
                  I ?
                  Sta uradi ?
                  Renault Laguna II 1,8 Privilege, juni 2004
