Oznake, ispravnost svecica [vizuelno]
  • vujke
    Admin
    • 1682
    • Mladenovac
    • Daewoo Lanos 1.5SX
    Izgled i uslovi koji ih proizvode u vasem motoru.
    Niterra ist der weltweit führende Hersteller der Marken NGK Ignition Parts und NTK Vehicle Electronics. Niterra ▶ beste Zünd- und Sensortechnik
    Na temu svecica je vec dosta receno, o tome možete videti ovde
    Normal appearance
    White-grey discoloration of insulator and some deposits.
    while(!asleep()) {sheep++;}
  • vujke
    Admin
    • 1682
    • Mladenovac
    Deposits
    Deposits
    With mechanically worn engines deposits are forming on the spark plug and allow glow ignition.
    • vujke
      Admin
      • 1682
      • Mladenovac
      Insulator breakage
      Ceramic breakage from mechanical cause (installation, transport, impact) or thermal shock.
      • vujke
        Admin
        • 1682
        • Mladenovac
        Melting
        Caused by detonation / pre-ignition.
        • vujke
          Admin
          • 1682
          • Mladenovac
          Carbon deposit
          Caused by detrimental operating conditions or too cold heat range.
          • vujke
            Admin
            • 1682
            • Mladenovac
            Spark-over
            Voltage flash-over due to moisture or dirt.
            • vujke
              Admin
              • 1682
              • Mladenovac
              Corona spot
              Normal brown discoloration due to deposits of electrically charged oil particles. No indication of malfunction or leakage.
              • Nenad
                • 06.01.2005
                • 1364
                • BBgd/Mow
                http://www.spark-plugs.co.uk/pages/tech ... gnosis.htm
                Boost or bust...
                  odlican link za cross refernce za mnoge tipove i marke svecica.
                  mozete uporedjivanjem sa jedne na drugu , naci zamenu bilo koje marke za bilo koju drugu
                  http://www.globaldenso.com/PLUG/cross_r ... index.html
                  ili da nadjete tacno za vas auto DENSO svecicu ...
                  http://www.globaldenso.com/cgi-bin/glob ... -maker.cgi
                    oznake svećica
