Turbo sestak - ubrzanje 0-300
  • tenzo RS
    • 01.11.2004
    • 309
    • Krusevac
    • Saab 9-3 TiD
    ...po meni jedina alternativa cetvorocilindricnog atmosferca...(sto se zvuka tice)...ali dobro mislim da to nije toliko bitno s obzirom na performanse ovog auta...
    ...Nissan Skyline R34 Kismo...
    P.S. ...brzina u miljama!
    8 i 300...u firungu !!!
    trazis kvalitetan turbo servis za remont turbine?
  • Skyline GT-R
    • 13.02.2005
    • 806
    • Chicago - My Kind Of Town
    Da, imam taj klip.Fenomenalno ubrzanje.Zapanjujuce kako ga bukvalno "baca" na 70km\h.Neznam samo koliko konja ima skyline?
    • Saabo
      • 1724
      • Vrbas
      • SAAB 9000 2.3T STAND
      Bas extra, a i vidi se da proklizava neko vreme kad dodje na 60...al kad krene...sila nema sta
        Kismo R34-GTR - Street Drag specifications:
        Current power: <Untested as yet>
        Best ET and MPH: <Untested as yet>
        Other performance: 0-100 km/h: 4.02 seconds (measured via GPS)
        0-200 km/h: 9.25 seconds (measured via GPS)
        0-300 km/h: 19.55 seconds (measured via GPS)
        Engine designation: Nissan RB26DETT: 2.6 litre, Double overhead cam, Electronic fuel injection, Twin Turbo
        Displacement: 2,568cc
        Bore x Stroke: 86mm x 73.7mm
        Redline: Upto 8,750 rpm
        Boost: Upto 2.0 Kg/cm2
        Static compression: 8.3:1
        Camshaft specs: HKS - 264 @ 10.8mm IN / 264 @ 10.8mm EX
        Note: Engine retains stock (standard) Nissan bottom end. I.e.: No modifications have been made to OEM crank, rods, pistons, bearings, etc.
        Engine specification:
        HKS cams 264/264 duration with 10.8 mm lift
        HKS valve springs with titanium retainers
        HKS vernier cam gears
        Kismo fully race-ported and flow matched head
        Nismo N1 water pump
        Nismo thermostat set at 62 degrees
        Nismo 1.3 Kg/cm2 radiator cap
        HKS Drag metal head gasket
        HKS head bolts
        Trust 50 mm dia. exhaust 6-1 manifold
        Trust T88-34D turbo
        Trust type C 60 mm wastegate
        Trust 100 mm down pipe into exhaust
        Blitz 100 mm NUR exhaust
        Nismo 450 HP (90mm) airflow meters (x2)
        Trust DRAG SPL 4 row intercooler with 100 mm piping
        RC Engineering 1000 cc injectors (x6)
        HKS fuel rail, dual feeds of -6 lines
        RC Engineering fuel pressure regulator
        Bosch motor sport fuel pumps - type 044 (x3)
        Kismo design swirl pot (1 liter)
        Apexi Power FC engine management system
        Apexi FC commander
        Blitz SBC boost controller
        HKS triple plate sintered clutch
        HKS SQV dump valves (x2)
        Wheels and ancillaries:
        Advan TCII 18 x 9.5 wheels (x4)
        Yokohama AVS sport 265/35/18 tyres (x4)
        • tenzo RS
          • 01.11.2004
          • 309
          • Krusevac
          • Saab 9-3 TiD
          @206
          ...na istom sajtu ima snimak i od spolja pa ko voli nek izvoli...
