Mazda Formula
  • Vocko
    • 25.04.2005
    • 4556
    • nBGd
    Mazda Formula
    Constructor: Star Race Cars, 10639 Glenoaks Blvd, Pacoima, CA 91331
    Chassis: Carbon fiber composite built to FIA standards with 19 U.S. gallon fuel cell
    Engine: 240 HP Mazda “Renesis” rotary engine with encrypted ECU including rev limiter, pit speed limiter, traction control, fuel trim.
    Transaxle: Six-speed sequential with no lift shift
    Suspension: Pushrod, inboard with two-way adjustable shock absorbers, adjustable rear sway bar, cockpit adjustable front sway bar. Front suspension tethered.
    Cockpit safety: FIA headrest/side head restraint, compatible with HANS device.
    Dimensions: Front track 61.5”, rear track 58.5”, wheelbase 100.5” and weight 1090 lbs.
    Brakes: Cockpit adjustable bias, 4-pot alloy calipers, vented, floating steel discs.
    Wheels: Front 9”w x 13”d, rear 11’w x 13”d, Forged aluminum, center lock
    Features: Adjustable shocks, sway bars, brake bias and wing angles
    Optional (Subject to testing and rules review): Data acquisition, traction control defeat, fuel trim control on steering wheel, pixel screen display
    A postoji i ovako nesto
    Dry Weight: 1140 lbs.
    Engine: Sealed Mazda 13B rotary
    Transaxle: Racing 5-speed plus reverse
    Carb: Weber 48 DCOE
    Wheelbase: 95 in.
    Track: Front: 59 in. Rear: 58 in.
    Brakes: 4-wheel spec discs & calipers
    Wheels: Front: 8x13 BBS Rear: 10x13 BBS
    Vise informacija, rezultata, raspored takmicenja i slika mozete naci na ovoj adresi:
  • X9
    • 28.06.2005
    • 3179
    • Wien-Sabac
    • RX-8 i X-9
    http://www.mazdausa.com/MusaWeb/display ... tsChampCar
    sa sledecom tehnikom:
    http://www.mazdausa.com/MusaWeb/display ... meter=cars
    No ROTOR no MOTOR...
