Civic
  • -Vedran-
    • 03.10.2004
    • 3255
    Civic
    1st Generation (72 - 79)
    The first Honda Civic was introduced on July 12, 1972. It came with either 2-door or 3-door body. 4-door model (w/o trunk) was added in 1973. Civics were firstly powered by 1.2L or 1.5L CVCC engines. CVCC was standardized thru the whole line since August, 1975. The 1.2L engine was then replaced by a 1.3L model in 1978. 1 million Civic were produced by 1976 and it reached 1.5 million a year later.
    Model: '72 1200GL (SB1)
    Length: 3545mm Width: 1505mm Height: 1325mm
    Wheelbase: 2200mm Track (F/R): 1300mm/1280mm
    Weight: 606kg
    Engine: SOHC In-line-4 (EB1) Displacement: 1169cc
    Compression Ratial: 8.6 Fuel System: Carburetor
    Max Power: 69ps@5460rpm
    Max Torque: 10.2kg-m@5460rpm
    Power of dreams !!!
  • -Vedran-
    • 03.10.2004
    • 3255
    2nd Generation (79 - 83)
    The Civic was redesigned and sized-up. Beside the 3-dr and 5-dr hatchbacks, 4-dr sedan and station wagon were also available. The engines were more powerful than before. CVCCII engines, with improved power output and gas mileage, came to the market in July, 1980. By May,1982, over 3 million Civic were sold.
    Model: '79 1460CX (E-SR)
    Length: 3870mm Width: 1580mm Height: 1350mm
    Wheelbase: 2250mm Track (F/R): 1360mm/1270mm
    Weight: 780kg
    Engine: SOHC In-line-4 (EM) Displacement: 1488cc
    Compression Ratial: 8.8 Fuel System: Carburetor
    Max Power: 85ps@5460rpm
    Max Torque: 12.3kg-m@5460rpm
    Power of dreams !!!
    • -Vedran-
      • 03.10.2004
      • 3255
      3rd Generation (83 - 87)
      CRX coupe was added to the Civic line and 5-dr hatchback was eliminated. While there was no significant growth in body size, the engine performance was improved. In 1984, a 135ps 1.6L DOHC 16-valve PGM-FI engine (ZC) became the power plant of the Si model of Civic and CRX. 4WD also came as an option.
      Model: '84 25Si (E-AK)
      Length: 3810mm Width: 1630mm Height: 1340mm
      Wheelbase: 2380mm Track (F/R): 1400mm/1415mm
      Weight: 815kg
      Engine: SOHC In-line-4 (EW) Displacement: 1488cc
      Compression Ratial: 8.7 Fuel System: PGM-FI
      Max Power: 100ps@5800rpm
      Max Torque: 13.2kg-m@4000rpm
      Power of dreams !!!
      • -Vedran-
        • 03.10.2004
        • 3255
        4th Generation (87 - 91)
        With independent double wishbone suspension and the lower and wider body, Civic became more capable of high speed cruising. Performance was more and more concerned. The VTEC technology, shared from Honda F1 race, came to street finally. A 160hp 1.6L DOHC VTEC engine (B16) was powering the top-of-line Civic and CRX SiR since 1989.
        Model: '87 Si (E-EF3)
        Length: 3965mm Width: 1680mm Height: 1335mm
        Wheelbase: 2460mm Track (F/R): 1450mm/1455mm
        Weight: 900kg
        Engine: DOHC In-line-4 (ZC) Displacement: 1590cc
        Compression Ratial: 9.5 Fuel System: PGM-FI
        Max Power: 130ps@6800rpm
        Max Torque: 14.7kg-m@5700rpm
        Power of dreams !!!
        • -Vedran-
          • 03.10.2004
          • 3255
          5th Generation (91 - 95)
          Station wagon was no longer available. Same engines remained, but tuned for more power. At the same time SOHC VTEC and VTEC-E were developed for low-cost power boosting and better fuel economy. A US-built Coupe was available since 1993.
          Model: '91 SiRII (E-EG6)
          Length: 4070mm Width: 1695mm Height: 1350mm
          Wheelbase: 2570mm Track (F/R): 1475mm/1465mm
          Weight: 1050kg
          Engine: DOHC VTEC In-line-4 (B16A) Displacement: 1590cc
          Max Power: 170ps@7800rpm
          Max Torque: 16.0kg-m@7300rpm
          Power of dreams !!!
          • -Vedran-
            • 03.10.2004
            • 3255
            6th Generation (95 - 99)
            SOHC VTEC was changed form 2-stage (lo-hi rpm) to 3-stage (lo-mid-hi rpm). Multi Matic Transmission became available. In 1997, a special race-tuned hatchback, known as " " was add to the line.
            Model: '97 (E-EK9)
            Length: 4180mm Width: 1695mm Height: 1360mm
            Wheelbase: 2620mm Track (F/R): 1480mm/1480mm
            Weight: 1050kg
            Engine: DOHC VTEC In-line-4 (B16B) Displacement: 1595cc
            Compression Ratial: 10.8 Fuel System: PGM-FI
            Max Power: 185ps@8200rpm
            Max Torque: 16.3kg-m@7460rpm
            Power of dreams !!!
            • The Punisher
              • 01.03.2006
              • 514
              • Beograd Wozhdovatz
              • Ford Taunus TC1
              Mislim da su slike nestale ili ih ja jedini ne vidim, ako i drugi ne vide, evo da okacim sto sam nasao:
              1.
              2.
              3.
              4.
              5.
              6.
              7.
              8.
              • sale vti
                • 05.12.2007
                • 316
                • bgd-zemun
                • ctr
                peta generacija,sta reci....naj naj naj
                Mess with the best, die like the rest!!!
                • Propeler
                  • 20.12.2007
                  • 125
                  • Subotica
                  Listam ovih dana neke stare auto-magazine i nadjem test novog Civica 1.8 i-VTEC pa reko da podelim sa vama, koga zanima. Novine su iz 2006.
                  Slike su malo vece rezolucije da bi se mogao citati tekst.
                  Nemam potpis!
                  • Propeler
                    • 20.12.2007
                    • 125
                    • Subotica
                    Takodje evo i Sedana.
                    Nemam potpis!
