Lancia Kappa
  • Sasha
    • 4126
    Lancia Kappa
    Malo smo zanemarili Lanciu,Kappa je po meni dosta interesantan model,pogotovo coupe
    The Lancia Kappa was introduced in 1994 to replace the Thema, as the pinnacle of the Lancia range. It was initially offered as a conventional three box, four door saloon with a choice of five engines, a 1995cc (205bhp) four cylinder turbo, a 1998cc (145bhp) five cylinder, a 2446cc (175bhp) five cylinder, a 2959cc (204bhp) V6 derived from that of Alfa Romeo, and a 2387cc (124bhp) five cylinder turbo diesel. A suspension layout similar to the Thema was adopted, and a high level of equipment was fitted in line with expectations in the luxury market segment.
    In June 1996 an estate version was introduced, the Kappa Station Wagon, designed by Pininfarina. This had the same engines as the saloon, the 1998cc five cylinder variant in both saloon and estate now being fitted with a variable geometry inlet manifold and producing 155bhp. Some minor changes were made to the saloon at the same time.
    www.arcs.org.rs/forum
  • Sasha
    • 4126
    In Geneva in 1997 Lancia unveiled the Kappa Coupe. A two door body, designed in house by Lancia, it had a 120mm shorter wheelbase than the saloon and estate and was built by Maggiore. Only the V6, 2400 five cylinder and 2000 four cylinder turbo engines were offered.
    1998 saw the replacement of the 2000 turbo four with a 1998cc turbocharged five cylinder engine (220bhp) and the replacement of the 2400 turbo diesel with a new 2387cc five cylinder turbo diesel (136bhp) using direct injection and common rail, called JTD. A variety of other small details were also changed at this time.
    Production ceased in the summer of 2000, after around 80,000 cars had been built. It was replaced by the Thesis.
    • Sasha
      • 4126
      Technical Details
      Driveline- transverse engine at front with front wheel drive
      Suspension- front : MacPherson strut with telescopic dampers and coil springs plus anti-roll bar rear : MacPherson strut with telescopic dampers and coil springs plus anti-roll bar wheelbase : 2700mm front track : 1546mm (saloon & SW); 1547mm (Coupe) rear track : 1527mm (saloon & SW); 1533mm (Coupe)
      Brakes-front : discs, ventilated, diameter : 281mm (2.0, 2.4, JTD); 310mm (2.0T, V6) rear : discs, diameter : 276mm handbrake operating on the rear via cable dual hydraulic circuit with servo assistance
      Gearbox- 5 speed manual 4 speed automatic
      Steering- Rack and pinion with power assistance
      Kerb Weight-Saloon : 2.0 20V : 1440kg; 2.4 20V : 1450kg; 2.0T : 1500kg; 3.0 V6 and 2.4JTD : 1510kg Coupe : 2.0T : 1475kg; 2.4 : 1425kg; V6 : 1515kg SW : 2.0 20V : 1510kg; 2.0T : 1560kg; 2.4 20V : 1520kg; V6 : 1610kg; 2.4JTD : 1580kg
      Performance
      ................................................ V-max. 0-100km/h standing km
      Saloon 2.0 20V (155bhp) 212 km/h 9.2 sec 30.6 sec
      Saloon & Coupe 2.0 20V turbo 243 km/h 7.3 sec 27.3 sec
      Saloon & Coupe 2.4 20V 218km/h 8.7 sec 29.6 sec
      Saloon 3.0 V6 225 km/h 8.0 sec 29.1 sec
      Coupe 3.0 V6 220 km/h 9.8 sec 30 sec
      Saloon 2.4 JTD (136bhp) 202 km/h 10.0 sec 32.0 sec
      SW 2.0 20V turbo 235 km/h 7.7 sec 27.7 sec
      SW 3.0 V6 218 km/h 9.0 sec 29.5 sec
      SW 2.4 JTD 200 km/h 10.8 sec 32.7 sec
      • Sasha
        • 4126
        Kayak
        Bertone kappa based coupe
        • Sasha
          • 4126
          Lancia Kappa Kombi 20VT.330PS
