Bmw e52 (Z8) 1999-2006
    kritike, na njemu svojstven nacin:
    Length: 4400 mm / 173.2 in
    Width: 1830 mm / 72 in
    Height: 1317 mm / 51.9 in
    Wheelbase: 2505 mm / 98.6 in
    Front track: 1553 mm / 61.1 in
    Rear track: 1568 mm / 61.7 in
    Ground clearance:
    Fuel: 73 liter / 19.3 U.S. gal / 16 imp. gal
    Turning circle btw. walls:
    Turning circle btw. curbs: 11.6 m / 38.1 ft
    Drag coefficient claimed: 0.43
    Trunk cap. SAE: 142 / / dm3
    5 / / cu ft
    Trunk cap. VDA: 203 / / / dm3
    7.2 / / / cu ft
    Engine
    manufacturer:
    BMW S62
    B50
    Engine
    type:
    spark-ignition
    4-stroke
    Fuel
    type:
    petrol
    (gasoline)
    Fuel
    system:
    indirect
    injection
    Charge
    system:
    naturally
    aspirated
    Valves per
    cylinder:
    4
    Valves
    timing:
    double-VANOS
    (Variable Nockenwellen Steuerung)
    Additional
    features:
    Siemens MSS
    52
    Emission
    control:
    3-way cat,
    Lambda-Sensor
    Emission
    standard:
    Cylinders
    alignment:
    V
    8
    Displacement: 4941 cm3 /
    301.1 cui
    Bore: 94 mm / 3.7
    in
    Stroke: 89 mm / 3.5
    in
    Compression
    ratio:
    11 :
    Power
    net:
    294 kW / 400
    PS / 394 hp (ECE)
    6600
    Torque: 500 Nm / 369
    ft-lb
    / 3800
