Zavoli Zeta-N 135 KW
  • Feed
    • 03.08.2011
    • 13
    • Feed Grad
    • Dostavno vozilo
    Zavoli Zeta-N 135 KW 12.07.2015 01:14
    5.466,37 Din. 5.045,88 Din.
    Isparivač Zavoli Zeta N do 135 Kilovata za sekvencijalni sistem.
    All the LPG regulators are homologated according to the EEC directives 67R-01.
    TECHNICAL DATA SHEET
    ITEM DETAIL
    Working Pressure 45 bar
    Outlet gas Pressure 1.2 bar
    Number of Stages 1
    Inlet gas fitting M12 x 1
    Outlet gas fitting Rubber hose
    Ø 10 mm
    Water Coolant Port Rubber hose
    Ø 16 mm
    MAP Port Rubber hose Ø 5 mm
    T range -20/ +120° C
    Agreement 67R-01
    Više...
