Istorijat Alfa Romea
  • Sasha
    • 4126
    The spaceframe of the TZ1 was built at Alfa Romeo?s Ambrosini factory, with the bodywork mainly being created at Zagato in Milan (there were also three glass fibre versions built by Balzaretti Modigliani of Milan), before final fettling and mechanical work was undertaken at Alfa Romeo?s Auto-Delta racing department. The 1.570 cc twin cam engines were also later developed by Conrero to pump out 160 bhp over the original 112.
    Bertone was supplied with a new TZ2 chassis (chassis number 101) for construction work to be held over the Autumn of 1964.
    In an attempt to make the Canguro design more suitable for any form of production, and also presumably because of the limited time span before the Paris Salon, 90% of the Canguro was made from Giulia TI components. Bertone continued the tubular framework construction for the aluminium bodywork. This firstly reduced the car?s weight tremendously, and suited a low profile shape for improved aerodynamics. Secondly the Gran Turismo character remained therefore intact.
    Whether the car was fitted with what would have been an experimental 170 bhp, twin sparkplug per cylinder TZ2 engine is currently unknown. However the Canguro?s sleek shape and lack of a bonnet bulge could indicate that the smaller dry sump TZ2 engine was used.
    Photos of the Canguro are misleading, as the actual car appears much lower than images suggest. Its length of 3.900 mm was conventional, as was the width of 1.600 mm. However, the Canguro was only 1.060 mm high, a dramatic 140 mm lower than the original TZ. It was therefore impressive that Bertone had managed to create a generally roomy two-seat interior inside such a low-down volume.
    In order to facilitate entry and exit from the interior, the doors curved through into the roof and were hinged far in front of the cockpit area.
    Strikingly low, the Canguro helped spark off a new direction for Italian road car design, following the principles of the 1963 Bizzarrini prototype (above).
    www.arcs.org.rs/forum
    • Sasha
      • 4126
      Above: Giorgetto Giugiaro created a sensational design, perfectly captured in this original rendering. Below: the Canguro featured many modern styling solutions, including a glued in front windscreen and general lack of chrome trim.
      The seats were positioned between the outriggers of the tubular platform below the floorpan to accommodate drivers exceeding six-feet. The occupants therefore sat only inches from the ground, which must have provided for an amazing sense of speed.
      Unfortunately the Canguro remained a concept study. After substantial interest at the Paris Salon, Bertone gave the car to Alfa Romeo for evaluation purposes. Alfa Romeo decided against building the car, presumably because their novel Auto-Delta racing department, which was set up on 6 March 1963, had to focus on developing the TZ2 and simply did not have the capacity to concentrate on a secondary model alongside. If production was to have followed, the bodywork would have undeniably been made from glass fibre. Alongside this, even more standard parts would have found their way onto the design.
      What happened to the Canguro after Alfa Romeo?s evaluation is exceptionally vague. One story states that the car was damaged at Monza by an Italian motoring journalist, after he veered into another Bertone prototype; the equally beautiful Chevrolet Corvair ?Testudo?, a design dating from the previous year and the personal car of Nuccio Bertone! This account mentions that the older Testudo was repaired, whilst the Canguro was pushed into storage behind Bertone?s Grugliasco factory.
      • Sasha
        • 4126
        Another, less believable, explanation clarifies that the prototype was loaned to a film crew and that Bertone never got the car back. Apparently, when Bertone managed to hunt the prototype down, they found it incomplete in one of the filming studios.
        At the end of the sixties, an American living in Bitburg, Germany, bought the remains of the incomplete car from Bertone for the cost of processing the paperwork (anything from between $35 to $125, depending on sources). At that stage the car was deteriorating outside the factory, missing its clamshell engine lid, valuable engine, gearbox, seats and interior trim.
        The new owner restored the car as far as he could, however was apparently forced to sell the project later on to a Japanese collector.
        As the Canguro was found at the Bertone factory at the end of the sixties, with missing parts. The car was bought and restored by an American living in Germany, and is thought to be currently in Japan.
        • Sasha
          • 4126
          The shape of the Canguro, in part inspired by the 1963 Bizzarrini prototype, later evolved into the mid-engined Lamborghini Miura, often voted as the most beautiful and forward-thinking supercar ever made.
          From that point on, the trail for this one-off Alfa Romeo exotic runs cold. Hopefully it will only be a matter of time before this Italian treasure is unearthed for public viewing once more.
          The Alfa Romeo Canguro represents one of the most important models in Bertone?s history, and bridges the design of the 1963 Bizzarrini prototype with the 1966 Lamborghini Miura. The Miura is often regarded as the most beautiful and forward-thinking supercar ever; however it is unmistakably an evolution of the Bizzarrini and Canguro in terms of style.
          By James Granger
          • Sasha
            • 4126
            The bank of 6 louvers on this Giugiaro rendering made their way onto the 1967 Alfa Romeo Montreal.
            Perfectly proportioned, the remarkably raked and curved front windscreen
            was later to be found on the Lamborghini Miura.
            In order to facilitate access to the low-down interior, the door cut-outs ran
            through into the roof.
            • Sasha
              • 4126
              Simple detailing - a typical Giugiaro trademark.
              Coda Tronca - simple yet effective. The round tail-light theme will make a
              comeback on the next generation Alfa Romeo hatchback - the Alfa 148.
              • Sasha
                • 4126
                The Kamm tail was a perfect translation of the TZ racing cars; after
                all, this was the design brief.
                Coda Tronca - simple yet effective both in aerodynamics and styling.
                • Sasha
                  • 4126
                  The front slats on the modified Alfa Romeo grille were painted black - a
                  styling cue well ahead of its time.
                  The Canguro concept - a TZ car for the road - is still inspiring Centro
                  Stile today. Here are some renderings of the Sportiva Evoluta (maybe a
                  hint also towards the Alfa 148).
                  • Sasha
                    • 4126
                    • Sasha
                      • 4126
                      Alfa Romeo disco volante (1952
                      • Sasha
                        • 4126
                        Alfa Romeo Giulia SS (1964)
                        • Sasha
                          • 4126
                          • Sasha
                            • 4126
                            TZ1 Coupe Zagato (1964)
                            • Sasha
                              • 4126
                              • Sasha
                                • 4126
                                159 Monoposto (1951)
