poludjeli brisaci na 156
  • E_K_V
    • 09.05.2005
    • 220
    • Podgorica
    evo od kad sam kupio auto sve funkcionise bez problema ali od pocetka imam problema sa brisacima....
    prvo kada ukljucim pranje vjetrobranskog stakla samo rade prskalice a brisaci ni makac...nego moram da povucem rucicu prema gore i da onda ukljucim pranje kako bi ujedno radili i brisaci i prskalice...
    drugo sto mi se desavalo jeste da kad ugasim brisace oni ostanu u poziciji u kojoj su se zatekli kada sam ih ugasio, a sad je pocela da se desavaja jos jedna stvar a to je da kada ukljucim brisace da rade periodicno i bilo koji interval da podesim oni samo krenu par cm i tu stanu i vise ne mrdaju makar dok ne ukljucim neku vecu brzinu....
    sto je problem ovdje? da li je neki automat koji kontrolise brisace ili opet neki alfini gremlini
    FERRARI THE ULTIMATE DREAM MACHINE
    there is nothing like ferrari.georgeus design and precision performance are the hallmarks of Enzo Ferrari`s automobiles....
  • E_K_V
    • 09.05.2005
    • 220
    • Podgorica
    da li je ovo mozda rjesenje za moj problem
    The intervals on the wipers are known to stop working
    after a while. When on slow intervals the wipers starts
    missing a sequence and makes strange sounds. This will slowly get
    more and more frequent until the slow intervals don't work
    any more.
    This is a common problem, but this could be your solution:
    Unscrew the wipers, then the plastic cover.
    On the drivers side you see the engine, take the cover off.
    You see wires coming in - disconnect then you can with the help
    of screwdriver open the part where electrical thingies meet
    engnine (you will see it).
    Problem is that there is a lubricant that gets stuck to
    electrical parts of that wiper engine and thus stops the
    movement. Solution is simple - just clean it and put it back togeather.
    I wan't to add that this is a common problem with all new Alfas (155, GTV, Spider..)
    • Guest's Avatar
      Re: poludjeli brisaci na 156
      Originalno postavljeno od E_K_V
      ha
      Ne gubi nadu brzo cje predstavnishtvo Delte!
      • E_K_V
        • 09.05.2005
        • 220
        • Podgorica
        ne gubim nadu ja tako lako ja sam nepopravljivi optimista inace ne bih uzeo alfu
        • coma
          • 25.02.2007
          • 7
          • Serbia
          • Alfa Romeo
          was ist das EKV?!
          ..samo se zalis nesto, sto ce ti brisaci, to ti je suvisna oprema, svratis u pitstop i operu ti sofersajbnu
          ...i ponude ti ljepse felne.. poz
