Ljudi jel zna neko nesto o autodati? Sta je to, cemu sluzi? I ako zna neko link za download... Ja sam pokusavao da skinem preko nekih torenta, ali nisu bili dobri... Hvala...
Autodata
Re: Autodata
Autodata covers a number of subjects including:
Technical data, vehicle identification, service adjustments, lubricants and capacities, ignition system, fuel system, tightening torques, brake discs and brake drums, repair times, wheel alignment, timing belts, timing chains and gears, tyre sizes and pressures, service illustrations, service schedules, service interval indicators, key programming, diagnostic trouble codes, engine management systems, pin data, trouble shooter, airbags/SRS, air conditioning, ABS, electrical component locations and wiring diagrams.
a ostalo je piraterija.You know your in an E30 when when your gas gauge waves hello to you constantly.
