Opel Astra G 1.7d modulator boš pumpe (gdje naći)
Re: Opel Astra G 1.7d modulator boš pumpe (gdje naći)
Vauxhall / Opel Astra / Combo / Corsa Fuel Pump EDU / ECU 16267710.
ecu pumpe ili komputer bosch pumpe. procitao sam u nekim postovima ovde na CBC dase to uspesno popravlja i kosta 150 eur. -
nema veze sto je vec popravljan :
yeah in most cases its just the dry joints just resolder using plenty of flux and test all should be good .worked for me 99 percent had one that was just too burnt to repair hope this helps,,good luck
http://www.digital-kaos.co.uk/forums/f1 ... elp-90965/
kazu da u 99% slucaja treba da se otvori i da se preleme spojevi ( hladni lemovi) .
mislim ,nemam iskustva ,ali eto mislim da se isplati otvaranje ponovo.
nemas sta da izgubis.Lakota withdraw from treaties, declare independence from U.S.Comment
