Outlaw Thermal Spacers
  • Vocko
    • 25.04.2005
    • 4556
    • nBGd
    Available for Mazda V6 Engines.
    Includes intake manifold spacers, throttle body spacer, gaskets, coolant bypass fitting, installation kit, detailed instructions
    Outlaw Engineering ThermoBlok spacers are thermal insulating replacements for your stock intake manifold and throttlebody gaskets. Made from a heat blocking phenolic laminate, ThermoBlok spacers increase power from your engine by keeping the intake cooler.
    Key benefits:
    » Produces a cooler intake manifold resulting in MORE POWER
    » A cooler intake charge also reduces the tendency for
    detonation, meaning ignition timing can be advanced for
    MORE POWER
    » Almost invisible modification, looks stock for the stealth factor
    » Better gas mileage
    » Replaces stock gaskets
    » Reusable over and over
    » No undesirable side effects
    Jeroentje.nl
  • X9
    • 28.06.2005
    • 3179
    • Wien-Sabac
    • RX-8 i X-9
    neko dobija news od jeroentje.nl
    ajd pogodi ko je vec naruchio
    No ROTOR no MOTOR...
    • RedboX
      • 28.11.2006
      • 1537
      • Novi Beograd
      u jamerici su ovi v6 120usd a za moju 99usd ali ovi nemaju
      • X9
        • 28.06.2005
        • 3179
        • Wien-Sabac
        • RX-8 i X-9
        105 dolara su za v6..za tebe ne znam
        • RedboX
          • 28.11.2006
          • 1537
          • Novi Beograd
          kolko god ovi ga olandjani bas deru, racunaj i troskove transporta i do tebe a kamo li do nas
          • X9
            • 28.06.2005
            • 3179
            • Wien-Sabac
            • RX-8 i X-9
            pa ne bih bas rekao...
            105 dolara + minimum 50 dolara postarina od amerike do austrije +carina koja bi bila sigurno min. 20,30 eura...
            znachi oko 150 dolara do mene(100 eura) plus carina izadje me skoro na isto...ovako cu manje da cekam
            • RedboX
              • 28.11.2006
              • 1537
              • Novi Beograd
              Da al zato sto imaju za tebe
              za moju mora od americana
              • X9
                • 28.06.2005
                • 3179
                • Wien-Sabac
                • RX-8 i X-9
                pa jesi ih pitao imaju li?
                mozda ti nabave pa onda vidi cenu....
                • RedboX
                  • 28.11.2006
                  • 1537
                  • Novi Beograd
                  jesi nesto uradio sa ovim i da li si uzeo ovo cudo?
                  Ako si narucivao daj mi neki kontakt da bar pitam kolko su za moju pa da te smaram da mi narucis dobro dam ti neki procenat i zelene patosnice
                  • X9
                    • 28.06.2005
                    • 3179
                    • Wien-Sabac
                    • RX-8 i X-9
                    uradio jos nista nisam jer chekam malo vremena da menjam....
                    jeroentje.nl
                    uloguj se i napravi pitanje-na engleskom jer holandski sigurno ne znas-kao ni ja....i dobices odgovor.
