raspored osiguraca BMW e30 316
  • Bobby
    • 09.08.2007
    • 7
    Treba mi rapored osiguraca i relaja za fuse box za e30 316!!!!
    Trazio sam po forumu ali nisam nasao valjda niko nije pitao, a u nekom service manualu koji ja imam u pdf-u uopste nema rasporeda. Inace ne radi mu ventilator kabine i elektro retrovizori na BMW-u mog drugara...
  • Hermes
    • 14.02.2006
    • 1309
    • bemve
    aFuse Rating (amps) Description
    1 7.5 Headlight, left high beam
    2 7.5 Headlight, right high beam
    3 15 Aux. cooling fan, low speed
    4 15 Turn signals / emergency flasher / Active Check control / Digital Clock
    5 30 Windshield wiper and washer
    6 7.5 Stop lights / Cruise control / Active check control / ABS / Interior Lights
    7 15 Horns
    8 30 Rear Defogger
    9 15 fuel delivery / Idle speed
    10 7.5 Seat belt warning system / Service interval indicator / Tachometer / fuel economy gauge / Instrument gauges and indicators / Brake warning system / Back-up lights / OBC / Starter / Fuel delivery / Idle speed / Active check control / Stop lights and cruise control
    11 15 1984-1987 7.5 1988-1990 Fuel pump
    12 7.5 Radio power / Speedometer / instrument indicators / OBC / Multifunction Clock
    13 7.5 Left Low Beam
    14 7.5 Right Low Beam
    15 Not in Use
    16 15 Heated Seats
    17 30 Sunroof / Power Windows
    18 30 Aux. cooling fan, high speed
    19 7.5 Aux. cooling fan / Interior lights / Power mirrors
    20 30 Heater / Air conditioner / Auxiliary Radiator cooling fan
    21 7.5 Glovebox lights / Flashlight / Ignition Key / Seat Belt warning / Interior Lights / Radio Memory / Trunk Lights / Active Check Control / Service Interval Indicator / OBC / Fuel delivery / Tachometer / Fuel Economy Gauge / Digital Clock / Multi Function Clock
    22 7.5 Active Check Control / Front Parking Lights / Taillights / Front Side Marker Lights
    23 7.5 Instrument Panel Lights / Front Parking Lights / Taillights / Rear Side Marker / License Plate Lights / Active Check Control / Rear Defogger / Multi Function Clocks / OBC
    24 15 Turn Signals / Emergency flasher
    25 Not in Use
    26 Not in Use
    27 30 Interior Lights / Central Locking / OBC / Radio Amplifier
    28 30 Lighter / Power Antenna
    29 7.5 Left Fog Light
    30 7.5 Right Fog Light
    Ovo je za 318i, ali mora da je isto sve
    • Bobby
      • 09.08.2007
      • 7
      Hvala komsija!!!
