Audi A4 detailing
    • 3173
    Audi A4 detailing
    Evo jednog njemca na pranju. Nije bio ni previše prljav, iako zapušten. Danas je urađen enterijer:
    Pre pranja:
ID:	885120Click image for larger version
ID:	885121Click image for larger version
ID:	885123Click image for larger version
ID:	885124Click image for larger version
ID:	885126Click image for larger version
ID:	885127Click image for larger version
    • 3173
    U toku pranja:
ID:	882753Click image for larger version
ID:	882754Click image for larger version
ID:	882755Click image for larger version
ID:	882756Click image for larger version
ID:	882757Click image for larger version
ID:	882758Click image for larger version
      • 3173
ID:	882763Click image for larger version
ID:	882764Click image for larger version
      Nakon pranja:
ID:	882766Click image for larger version
ID:	882767Click image for larger version
        • 3173
ID:	882769Click image for larger version
ID:	882770Click image for larger version
ID:	882771Click image for larger version
          Imam jednu 147 , kada imaš slobodan termin
            • 3173
            Na prolece Smrzao sam se ko p...a a
            Evo malo i nastavka:
ID:	882773Click image for larger version
ID:	882776Click image for larger version
ID:	882774Click image for larger version
              A sta ces da radis do proleca?
                • 3173
ID:	882777Click image for larger version
ID:	882778Click image for larger version
ID:	882779Click image for larger version
ID:	882780Click image for larger version
ID:	882781Click image for larger version
                  • 3173
                  Ako uspem da prodam audija, uvescu jos neki auto pa cu opet da se smrzavam ovako po ceo dan
                  Juce sam radio od 9 do 16h, danas duplo krace. Ne mogu vise da se smrzavam
                  Sutra nastavak.
                    Nemam reči Danas je baš spičotina, zeznem se pa odem na pijac, pojeo pljeskavicu i nazad
                      Bas cudno, krenuo na pijacu, zavrsio u kafani ili cuftari
                        Nije čudno, Najlon, pun kafana i ćuftara
                          @sergio , znaci viler-diler si postao , nema tabli,uvoz?
                          a agencija za bezbednost ne radi, a kad ce neznamo
                            • 3173
                            Jeste uvezao sam ga. Trenutno je neka smena direktora u amss pa se cekaju potvrde malo duze, ali sta da se radi.
                            Jedno amatersko poliranje kasnije:
ID:	882783Click image for larger version
ID:	882784Click image for larger version
                              Kako ne znamo, pise u oglasu za par dana
