Da nije Excalibur?
Mali Kviz!!! Koji je ovo automobil?????
Neki od Fiata serije 51x ili Ford A tudor, na njih mi najviše liči, ali problem je što su automobili iz tog perioda bili skoro identični, osim par slavnih izuetaka... Nemam sad vremena da dalje tražim šta bi moglo biti155+75=230
VIVA LA VITA!!!Comment
Ajde jos malo pomoci, auto je iz Italije.
Finally entering in production in 1924, the car used an innovative monoblock reinforced-aluminium chassis (resulting in a low weight of 420kg), a 565cc four-cylinder side-valve in-line engine (producing 18bhp) with a single overhead camshaft and a three-speed gearbox. As could be expected coming from such a company, aluminium was used everywhere, including the wheel, pistons, cylinder head, exhaust manifold and all pipes, tubes, handles, brackets, etc.. Drum brakes were fitted at the rear, operated by the brake pedal, whilst the handbrake operated on the transmission.Comment
