samo u ameriKi
  • srdjanissan
    • 20.11.2008
    • 720
    samo u ameriKi
    Lik je menjao ulje i sta je konkretno uradio i na koji način ,pročitajte
    http://www.mustangforums.com/forum/5-0l ... s-car.html
  • sn00py
    • 15.08.2005
    • 851
    • Belgrado
    Re: samo u ameriKi
    Lik je objasnio hhahhhaa
    BMS team
    • madic
      • 07.10.2007
      • 844
      Re: samo u ameriKi
      Stvarno je objasnio, mada uvek može da se desi da ih neko loži do kraja.
      • YugoRS
        • 28.12.2008
        • 27
        • Beograd-KZS
        Re: samo u ameriKi
        Ako je ovo stvarno istina onda ja nemam reci...objasnio je par stvari... BAHATO GLUPI KRETEN!!!
        -YUGO][RS]=-
        • uglavnom.bezopasni
          - 42 -
          • 03.02.2005
          • 2235
          • Citroen
          Re: samo u ameriKi
          Jedna jako ozbiljna poruka na jednom jako ozbiljnom forumu za podršku, svaki dan bude bar po jedna, ali ova me je tako ganula:
          Never! Never! Do this with Filezilla!!!
          Let me state right up front I've gotten an outstanding education this week from Rick and David. Thank you guys for all you've taught and "made" me learn. It is all worth it and all good.
          While trying to change my wp_prefix via MySQL and phpMyAdmin, I learned to download the free FTP software Filezilla. Watched a video tutorial, connected to my site and commenced to follow the directions to check my write ability of my wp_config.php file. Done deal! BTW, I wasn't able to get the wp_prefix to change so here's what I did.
          I deleted the entire WP program, comfortable in the fact that this was my fifth time installing it and knew I would get it right this time. All went very smoothly using the directions provided for install by Rick in another thread just a day ago.
          I was so proud of myself at what I had learned and applied this week. Went back to my Filezilla screen and saw all of these files I had downloaded and thought, "I don't want all of these files taking up space on my hard drive." I commenced, albeit without thinking, DUH! and pressed the delete key for........."Remote Site Files." As soon as they started to disappear, I knew I was soooo screwed!!!! So, DO NOT DO THIS UNDER ANY CIRCUMSTANCES!!!
          Luckily, I followed Rick's and Dave's instructions on another subject I worked on this morning and did a backup of my primary account directory. I was able to cancel my emergency restore request with HG Support and get right back to where I was before this major FUBAR I created.
          Lessons all well learned this week. Never, never, never give up the faith in yourself and that of the mentors on this forum.
          With Sincere Gratitude,
          Craig
          11.04. 0:12 #2
          • somi_kac
            • 03.04.2009
            • 796
            • Kać
            Re: samo u ameriKi
            Cccc... Kakve imbecile Bog pusti na zemlju!
            Ima lik kod nas koji je kupio apenca, pa hteo sa upaljacem da vidi jel' ima goriva. Da vidite kako se katapultirao 2m od zemlje...
            OPEL Astra 1.6i
            OPEL Kadett 1.6
            ŠKODA Favorit
            • Cherokee_NS
              • 08.02.2009
              • 802
              Re: samo u ameriKi
              Ajde nije to nista. Lik u dvoristu provalio rupu u koju se legu pacovi... Uzme butansku bocu onu za kucu, namontira crevo, gurne crevo u rupu i odvrne gas... I lik posle nekog vremena vidi da se nista ne desava (kontao da ce pacovi mozda izaci napolje)... Posto je rupa bila mracna, uzme on upali upaljac i prinese rupi da osvetli da vidi sta se desava .... To kad je puklo prozor mi se tresao u sobi... Uglavnom, lik je razorio sebi beton u dvoristu, on je prosao ok tj leteo je jedno par metara i jos se cudi sta ga je snaslo...
              • srdjanissan
                • 20.11.2008
                • 720
                Re: samo u ameriKi
                pa nisu kanarinci,pa da ih gasom truje..,ne verujem.mogao je kucu dici u vazduh
                • Cherokee_NS
                  • 08.02.2009
                  • 802
                  Re: samo u ameriKi
                  Sta da radim kad imam zanimljiv komsiluk
                  • srdjanissan
                    • 20.11.2008
                    • 720
                    Re: samo u ameriKi
                    bolje bi ti bilo da se selis,drugarski savet... dok nisu poceli pastete da kopaju po egipatskom stilu zakopavanja mina.
                    • stalker92
                      • 05.09.2008
                      • 243
                      • Novi Sad, Srbija
                      • 1981 Ford Taunus Tc3
                      Re: samo u ameriKi
                      Originalno postavljeno od Cherokee_NS
                      Pre par godina sam u novinama citao o clanak o tome kako su da li u Backoj Palanci ili u Backoj Topoli otac i sin pokusali da zavare neeksplodiranu kasikaru kao kvaku na kapiju. Epilog: Obojica poginuli.
                      Takodje ne znam da li znate za Darwin Award (nagrada koja se dodeljuje svake godine coveku koji pogine na najgluplji nacin)... tek cega tamo ima...
