Zezanje [ARHIVA]
  • Gazda Milutin
    • 31.01.2008
    • 267
    • Pancevo
    Re: Zezanje
    Jos offtopic
    Kolega X je u pravu.
    Buni vas taj visak bregastih...
    II deo 4.40 min po pocetku... Lepo se vidi OCT 21 2015. Cak Doc i MArty komentarisu taj datum. - Imam celu triologiju pa pogledah a ne znam kako da uradim jbni "print screen"
    Teska srca moramo priznati da je kolega Somi OPET u pravu kao i u slucaju "viska" bregastih!
    - Govori tiho i vodi psa sa sobom! -
    • X9
      • 28.06.2005
      • 3179
      • Wien-Sabac
      • RX-8 i X-9
      Re: Zezanje
      os ti posaljem 4-ti deo ako nemas?
      No ROTOR no MOTOR...
        Re: Zezanje
        hm, promakao mi je taj detalj
        somi, ovim putem ti se javno izvinjavam, kanda si u pravu za datum
        ko zna, kada bi se udubili u alfu, sta bi sve saznali...
          Re: Zezanje
          Cekaj, jel sad upravu i za bregaste ili?
            Re: Zezanje
            Bojim se da postoji mogucnost da jeste.
            • X9
              • 28.06.2005
              • 3179
              • Wien-Sabac
              • RX-8 i X-9
              Re: Zezanje
              vi niste normalni
              • Gazda Milutin
                • 31.01.2008
                • 267
                • Pancevo
                Re: Zezanje
                Originalno postavljeno od X9
                Nabavih ga josh zimus.
                A povadio sam i sve "viskove" iz motora. Sada je laksi, brzi, bolji... Odvazan je to potez...Somi mi otvori oci.
                  Re: Zezanje
                  Samo vi njajte ke pa kad se uvredi neće imati ko da vam objašnjava a onda će vam djavo biti kriv
                    Re: Zezanje
                    The European Commission has just announced an agreement whereby English will
                    be the official language of the European Union rather than German, which was
                    the other possibility.
                    As part of the negotiations, the British Government conceded that English
                    spelling had some room for improvement and has accepted a 5- year phase-in
                    plan that would become known as "Euro-English".
                    In the first year, "s" will replace the soft "c". Sertainly, this will make
                    the sivil servants jump with joy. The hard "c" will be dropped in favour of
                    "k". This should klear up konfusion, and keyboards kan have one less letter.
                    There will be growing publik enthusiasm in the sekond year when the
                    troublesome "ph" will be replaced with "f". This will make words like
                    fotograf 20% shorter .
                    In the 3rd year, publik akseptanse of the new spelling kan be expekted to
                    reach the stage where! more komplikated changes are possible.
                    Governments will enkourage the removal of double letters which have always
                    ben a deterent to akurate speling.
                    Also, al wil agre that the horibl mes of the silent "e" in the languag is
                    disgrasful and it should go away.
                    By the 4th yer people wil be reseptiv to steps such as
                    replasing "th" with "z" and "w" with "v".
                    During ze fifz yer, ze unesesary "o" kan be dropd from vordskontaining "ou"
                    and after ziz fifz yer, ve vil hav a reil sensibl riten styl.
                    Zer vil be no mor trubl or difikultis and evrivun vil find it ezi tu
                    understand ech oza. Ze drem of a united urop vil finali kum tru.
                    Und efter ze fifz yer, ve vil al be speking German like zey vunted in ze
                    forst plas.
                    If zis mad you smil, pleas pas on to oza pepl.
                    • prolupator
                      • 02.09.2005
                      • 3968
                      Re: Zezanje
                      prolupator.mojblog.rs
                      • Dzoni_mkv
                        • 29.04.2007
                        • 875
                        • Kraljevo, Pinsk-Belorusija
                        Re: Zezanje
                        Odlicno!
                        • X9
                          • 28.06.2005
                          • 3179
                          • Wien-Sabac
                          • RX-8 i X-9
                          Re: Zezanje
                          @eon
                          to br vise zvuchi na holandski nego nemachki
                          • rajmax63
                            CBC Prijatelj
                            • 1415
                            • Bačka Palanka
                            • AUDI A6 2.0TDI 170KS
                            Re: Zezanje
                            Ekonomska kriza
                            Pitanje dana :
                            Hoce li dolar pasti ?
                            Naravoučenije:
                            U vreme krize, treba stisnuti ****.
                            Audi ima crveno T
                              Re: Zezanje
                              Pa ovde će za jedno 30 do 40 godina pasti ili skroz potonuti u tamo...
                              Nešto se razmišljam kako je onom čiki na slici, pored tebe bazen, svi se kupu, raduju i vesele a ti ceo život u rudniku
                              • zverko
                                • 19.08.2005
                                • 7084
                                Re: Zezanje
                                * 1986. година. Прво полетање са нишког аеродрома.
                                Стјуардеса: - Лејдиз енд џентлменс, немо си јебете матер да рипате по авион, јер није ш'афен него лепен...
                                ИЗГИНУСМО КО МАЧИЋИ НА САПУЊАВУ ДАСКУ
                                "ЗА ОВУ ПАМЕТ ШТО ИМАМ, МАЛО САМ ДОБИО БАТИНЕ ОД МИЛИЦИЈУ"
                                ТОЛИКО САМ ЈЕО ГОВНА ДА НЕЋУ... ДА МИ ЈЕ САД ГЛУПО ДА ОЋУ!
                                ЋЕ ИЗГИНЕМО КИ МАНЦХЕСТЕР
                                ТАЈ ТВОЈА ГЛАВА НИЈЕ ЗА ДВЕ НОГЕ
                                КОГ ЖАНДАРИ ТЕПАЈУ.......... ТАЈ И ПОШТАРУ ЉУБИ РУКУ!
                                УБАЦУЈЕ СЕ КО ЦИГАНЧЕ У КОНТЕЈНЕР!
                                КО БАТИНУ НОСИ, ТРИ ЈЕЗИКА ПРИЧА
                                - Плиз, немо' да ровеш ...
                                - Ће те ицепим ко сељак пиво испред задругу!
                                - Зајебан си ко кратко ћебе
                                - Исцерио зуби ко згажено куче
                                - Напалио се ко дабар на кубик дрва!
                                ....ко бубамара на 'ектар детелину!
                                - Има да изгинемо ко Власи на рингишпил.
                                - Уредио сам си живот ки свиња башту
                                - Ће те поцепам ко педер Плејбој
                                - Ћу те изнабадам ко сељак притке у парадајз
                                - Ћу те згазим ко ФАП жабу
                                - Издуо се од алкохол ки пчеларски приправник
                                izvinjavam se sto je cirilica posto je u pitanju copy/paste ali padoh sa stolice
