Hakeri-Kakeri i ...
    Hakeri-Kakeri i ...
    A user with IP address 113.139.155.141 has been locked out from the signing in or using the password recovery form for the following reason: Exceeded the maximum number of login failures which is: 3. The last username they tried to sign in with was: 'dora'
    User IP: 113.139.155.141
    China negde
    113.139.155.141 IP Information
    A user with IP address 117.34.129.186 has been locked out from the signing in or using the password recovery form for the following reason: Exceeded the maximum number of login failures which is: 3. The last username they tried to sign in with was: 'dora'
    User IP: 117.34.129.186
    China negde
    117.34.129.186 IP Information
    A user with IP address 188.165.248.41 has been locked out from the signing in or using the password recovery form for the following reason: Exceeded the maximum number of login failures which is: 3. The last username they tried to sign in with was: 'admin'
    User IP: 188.165.248.41
    User hostname: ns380282.ip-188-165-248.eu
    Pariz France
    188.165.248.41 IP Information
    A user with IP address 204.12.207.58 has been locked out from the signing in or using the password recovery form for the following reason: Exceeded the maximum number of login failures which is: 3. The last username they tried to sign in with was: 'format'
    User IP: 204.12.207.58
    United states
    204.12.207.58 IP Information
    I još desetak za popodne... Dokone smrdibube iz sveta napadaju i provaljuju u ne znam ni ja šta...
    Ja razumem kad neko ima znanja pa hakuje neki sistem da bi nešto pokazao ili maznuo. Ne odobravam ali razumem. Ove šupke koji imaju neku skriptu koja gadja rupe koje su oni pravi otkrili a onda mali iz kraja uzme skriptu i traži, skenira itd...
    admin je po difultu nalog za Wordpress i većina ga ostavi kao takvog i onda šupci gadjaju pass za admina. A zašto, da bi napravili prvu stranu ovde je bio strašni kaker mudri baja... obliže mi nogu kad idem kroz šumu i stanem u ovno...
    A gde su oni sa podmornice?
      A ne.. ono su bili dobri, nisu hakovali nego su pristupali od ispod Afrike
      • vulkan
        • 03.09.2011
        • 151
        • sabac
        • mazda nisan
        Mene baš često raspoloži dorin smisao za humor. U raznim temama. Kad će nova epizoda priče iz nesvesti ili kako se beše zove? Toliko je davno bilo da sam zaboravio.
        • shime
          • 22.05.2011
          • 79
          • Vlasotince
          • Peugeot 405
          Sa raznih kontinenata bi da budu admini cbc foruma Ako mozete da banujete opsege ip adresa sa kojih stizu pokusaji bar na neko vreme dok se klinci ne ohlade.
            Izvinjavam se podmorničarima i onima sa naftnih platformi.
              Nema opsega, ima ih sa svih strana i to je nonstop, nije samo CBC, ima par wordpresova na serveru, njih više gadjaju pošto ima dosta modula i koječega. Naše je da sprečavamo a njihovo je da kakerišu
              Što se tiče vesti, situacija jes uviše napeta za neki humor, radimo na tome da se popravi
                Jel i ovo rezultat nekog hakerisanja?
                  Neznam šta i kako msliš a na osnovu slike ništa ne zaključujem...
                    Otvorim stranu, a na njoj umesto normalnog teksta vidim samo onako razbacana slova. Kad se izlogujem i posle nekog vremena ponovo ulogujem, sve bude normalno.
                      Greška do neta
