MSN
  • stefanves
    • 10.12.2006
    • 1351
    • BG
    MSN
    Napravio sam mail na hotmailu, probao da se logujem i nece, pise da treba update. Skoknem do neta skinem Windows Live messinger i porabam da se loguje, i on mi izbacuje gresku 80048820 .Ne znam da nije do toga sto mi Internet Explorer ne radi(nece da nista da ucitava, probao sam da ga dignem na 7.x verziju ali opet isto).Zna li neko resenje za ovo?
    Konacno i ja imam auto :-)
  • TheWickerMan
    • 11.09.2007
    • 791
    • DE
    • AR Giulietta TCT
    Pazi,meni je Zone Alarm pravio problem pri logovanju na MSN,tako da ako ga imas,iskljuci ga pa probaj.
    • GoranBG
      • 29.04.2007
      • 282
      • TU5J4
      I meni se to desavalo,proveri da li ti je dobro podesen sat na kompu odnosno vreme i datum
      • Marcus
        • 19.10.2007
        • 631
        • Novi Beograd - B62
        Evo sta sam nasao na stranom sajtu vezano za tu gresku i kako se otklanja...
        Causes
        * The system clock may be set incorrectly.
        * The Dynamic Link Library (DLL) softpub.dll, may not be registered on the system.
        * Internet Explorer may be using an invalid proxy server.
        Resolutions
        * Double click on the clock in the taskbar and make sure the system clock is set correctly.
        * Register softpub.dll using the regsvr32.exe tool.
        1. Click Start, and then click Run.
        2. In the Open box, type regsvr32 softpub.dll and then click OK.
        3. Restart MSN Messenger.
        Remove any Internet Explorer proxy server settings
        1. In Internet Explorer, click Tools and then click Internet Options.
        2. In the Internet Options dialog box, go to the Connections tab.
        3. Click LAN Settings…
        4. Untick the Use a proxy server for your LAN (These settings will not apply to dial-up or VPN connections) checkbox.
        5. Click OK and OK again Internet Options.
        evo i originalnog linka, imaju i neke slike http://www.fanatic.net.nz/2005/08/30/so ... -80048820/
        valjda je pomoglo...
        • krstin
          • 14.09.2007
          • 223
          Ako imas telekomov ADSL uradi sledece:
          U browser kucaj 192.168.1.1 ( ako je modem povezan preko mreze) ili 192.168.1.2 ( ako je modem povezan preko USB-a ). Kada trazi username i pass unesi admin (i kao username i kao pass). Nakon toga idi BASIC -> WAN settings i sa desne strane klikni na ikonicu u obliku olovke. Nakon toga, u donjem delu idi na Configured MTU i umesto 1432 stavi 1480. Na kraju klikni na Submit pa Save all.
          • stefanves
            • 10.12.2006
            • 1351
            • BG
            Nisam na Telekomu, vec sam na Madnetu. To je bezicni internet(WIFI). Mislis li da je to zbog provajdera, ili je mozda i do samog PCa(nikako da se nakanim da probam na laptopu)?
            • krstin
              • 14.09.2007
              • 223
              Mislim da je do providera, pre je dosta njih imalo isti problem na telekomu i ovako su ga resavali...
              • stefanves
                • 10.12.2006
                • 1351
                • BG
                Reinstalirao sistem jer se nesto sjebao, i sada radi
                • dacha
                  • 23.06.2007
                  • 356
                  • Beograd, NBG
                  • Xsara II 2.0i
                  Originalno postavljeno od krstin
                  dodao bih da ovo vazi samo za mt882 modeme dakle samo za 1 model od 6 koliko ih deli telekom. i nakon save all je potreban reboot modema da bi promena imala efekta, mada ne vidim neku vezu izmedju velicine paketa koju definise mtu i msn-a al dobro, ako kazes da je pomagalo ne kosta nista da se proba.
