ko je Stig? - Top Gear
  • ///M_Power
    • 05.05.2008
    • 335
    • Beograd - Minhen
    http://globalmotors.net/top-gear-test-d ... n-collins/
    Top Gear test driver The Stig is Ben Collins?
    Posted on Jan 19 2009 by Daily Editor
    There have been numerous speculations about who is The Stig. Some have speculated that it is Julian Bailey, Damon Hill, Tim Schrick or Russ Swift. One thing is sure that the man in Stig’s white suit has changed over the years.
    The first Stig, stunt driver Perry McCarthy, lost the job after outing himself in his book Flat Out, Flat Broke, published in 2002.
    Now the identity of current Stig has been unmasked as a professional stuntman and Le Mans racer Ben Collins.
    Collins outed himself to a staff at a Bristol gallery. The 33-year-old let his secret slip when he asked them to help him produce a limited-edition print of The Stig in action.
    Also a builder Jason Goody, 21, discovered The Stig’s identity when he did some work at Collins’ home and found the famous white suit and gloves on display in a cabinet.
    Top Gear spokesman said: “We never comment on speculation as to who or what The Stig is.” Collins of course denies all this, as his job is at jeopardy.
    Collins also recently spent three months working as a precision driver on the latest James Bond movie The Quantum of Solace.
    He was the double for Daniel Craig and drove the Aston Martin DBS in some of the most challenging driving sequences.
  • Byk
    • 24.01.2007
    • 105
    • Kragujevac
    Re: ko je Stig? - Top Gear
    Konacno i ta misterija da se zavrsi!!!
    vectra 2.0 DI
    kangoo 1.9D
    • Bane R
      • 27.03.2006
      • 1769
      Zašto opterećivati mozak ovim stvarima?
      Stig je virtuelna ličnost jednako virutealna kao što su likovi Ričard, Džejms i Džeremi u Top Gear.
      I ko što je stig u realnosti neko drugi, tako su i u realnosti ova trojica neko drugi. Morate da shvatite da je to sve gluma i scenario.
      Što uz jednu od najkvalitetnih tv produkcija na svetu daje legendarno dobru tv zabavu ...
      • skijash
        • 07.09.2007
        • 1354
        • wrx
        Khm khm
        • ///M_Power
          • 05.05.2008
          • 335
          • Beograd - Minhen
          • Armageddon ///M
            • 26.04.2008
            • 447
            • SRB
            • Ne
            Meni je trulo sto su provalili
            Ambitious but rubbish.
            http://www.youtube.com/streetracerm5
            • starac vujadin
              • 27.08.2005
              • 2617
              • Stari grad
              Najverovatnije jeste Ben Collins jer je on stalno na snimanju. Medjutim, ako i jeste on sigurno nije vozio Renault F1. Formulu je vozio ili Kovalainen ili Herbert. Do sada je bilo najverovatnije 3 Stiga, sto i nije los fazon jer tako mogu da menjaju vozaca, a da se to ne primeti, pa samim tim i da ga manje placaju. Inace Collins od ove godine ce voziti ozbiljne trke po Americi, tako da ce Top Gear morati da potrazi nekog novog Stiga.
              • Darth Nihilus
                • 13.04.2005
                • 417
                • Srbija, Paracin
                Glasam za onog FAT-Stig-a iz serija u Americi.
                Do not underestimate the power of the Dark Side
                • Dzoni_mkv
                  • 29.04.2007
                  • 875
                  • Kraljevo, Pinsk-Belorusija
                  Mislim da je ipak bolje africki Stig Bolje tera onu krs mecku
                  Mada se odavno zna da je Stig=Ben Colins tj. beli Stig. Stig koji je nosi tamni kombinezon (Perry McCarthy) je "stradao" kada je sa nosaca aviona pokusao da sa Jaguarom sa moooogooo N2O ubrza i uspori do kraja palube...........
                  • Bane R
                    • 27.03.2006
                    • 1769
                    Inače Top Gear je izdao zvanično obaveštenje ko je Stig...
                    Po njihovom saopštenju Stig je u stvari pokojni Grejam Hil koji je još davno iscenirao svoju smrt
                    • Bane R
                      • 27.03.2006
                      • 1769
                      Originalno postavljeno od starac vujadin
                      Ima tu još jedna po meni zanimljivija stvar... Reno F1 je navodno vozio stazu ispod minut... samo trajanje video snimka od početka do kraja kruga je bilo malo preko minut... pod uslovom da su prikazali kompletan krug... Ne pričam ovo zbog renoa, daleko od toga, nego prosto stvar koja potvrđuje ono što Klarkson navodi da "laži čine televiziju zanimljivijom...".
                      • mupe
                        • 05.10.2006
                        • 822
                        • bg
                        • Laguna 3 GT 2.0T 205
                        Ne vredi ti da meriš dužinu snimka jer je krug snimljen sa više kamera na kojima se pojedini delovi kruga preklapaju. Na primer, kamera kod onih guma i kamera neposredno pre nje su delimično preklopljene.
                        A 100% se slažem za ono oko Klarksonove izjave...
                        • Marko001
                          • 09.09.2006
                          • 1070
                          • Belgrade
                          Mozda je Mladen Alvirovic
                          • mupe
                            • 05.10.2006
                            • 822
                            • bg
                            U jednoj od novijih epizoda fifth geara su spomenuli da je stig možda tiff needel.
                            • jombaue
                              • 27.11.2008
                              • 55
                              • Novi Sad/Uzice
                              Jedna od zanimljivijih izjava, na koju sam naleteo na nekom sajtu, ne secam se gde taco, je da je Stig ustvari Cak Noris
