Ikariam (ekonomsko-ratno-diplomatska strategija :)
  • MarkoJTD
    • 04.05.2008
    • 249
    The story of Ikariam starts on a sunny island in the Mediterranean:
    Industrious workers, soldiers and researchers build on their own little empire between white beaches and rocky hills.
    The many thousands of players of the latest Gameforge browser game first jointly work on exploiting the raw materials of the island better, before using trade and also the help of their soldiers to grow into a glorious people.
    Every clan of fighters, however dauntless, is doomed without forming alliances and making commercial agreements, without supporting other peoples and using the assistance of friends.
    Ikariam shines not only with its graphics that can compare with any modern computer game, but also with a fascinating mix of trade, warfare and diplomacy.
    zanimljiva web browser igrica, ima ceo svet za podrucije srbije.
    - Italian for style
  • uglavnom.bezopasni
    - 42 -
    • 03.02.2005
    • 2235
    • Citroen
    Re: Ikariam (ekonomsko-ratno-diplomatska strategija
    Neka varijanta Traviana...
    Kod:
    Корисничко име мора да садржи између 3 и 30 знакова.
    Pa sadrži, hoću ja da budem ja...
    11.04. 0:12 #2
    • MarkoJTD
      • 04.05.2008
      • 249
      da, nesto ko travian, ali graficki naprednija.
      - Italian for style
      • little
        • 912
        • Lancia Ypsilon 1.2 8V
        oho, ako je kao Travian, ona ću se igrati, a ako nije počupaću vam usi
        "zensko si brate"
        Some people are wise and some.. Otherwise..
          - 42 -
          • 03.02.2005
          • 2235
          • Citroen
          Ovako spolja po svemu liči, a meni ne daju da se igram kao ja, onda neću ni da se igram
          11.04. 0:12 #2
          • BaneT
            • 09.12.2005
            • 562
            ja napravio nalog, simpatično.
            • MarkoJTD
              • 04.05.2008
              • 249
              ostavite koordinante i naziv grada, pa ako vam trebaju resursi da se pomazemo
              ja sam na ostrvu Laetios [35:59] grad: Vicograd
              - Italian for style
              • BaneT
                • 09.12.2005
                • 562
                šta bi jel igra ovo neko?
                ja se totalno navukao
                • Crki
                  • 26.07.2008
                  • 71
                  • Požarevac
                  • ford fokus
                  Meni je lepši travian,u prvom momentu sam bio razočaran, prosek godina 15 dok nisam video da ima i starijih od mene )) E sad da li što sam navikao na travian ali mi se ikariam nešto ne sviđa-čini mi se kompikovaniji.Ime mi je Crki
                    29:71
                    Eon city
                    Šaljite resurse... i ukratko kako se najbrže razvija i igra.
                    • BaneT
                      • 09.12.2005
                      • 562
                      eon mnooooooooogo si mi daleko
                      ajde skupi resurse za drugi grad pa ga napravi bliže meni
                      ću ti javim gde
                      u čemu je caka.....kada počinješ važi jedno i samo jedno pravilo.....nema štekanja resursa, dakle što iskopaš ...troši, na taj način te neće dirati veći od tebe (uvek te špijuniraju i kad vide da nemaš resurse ne diraju te)....istražuj redom istraživanja i mirna Bačka. kad izučiš kolonizaciju možeš da praviš drugi grad onda lepo srušiš prvi i odmah praviš još jedan
                      savez ti omogućuje brži razvoj to je sigurno. mene navukoše neki mangupi
                      šalu na stranu, što kaže Crki ja kontao da batalim ovo jer sam mislio da su samo klinci....cvrc ima ih od mene starijih koliko oćeš.
                      Ovi kod mene u Savezu su extra likovi i zajebancija je na nivou.
                      Za svako eventualno pitanju tuj sam....
                      p.s. Eon probaću da nađem nekoga ko ti je blizu pa da ti pomogne jer meni treba 13h samo do tebe pa još toliko nazad
                      EDIT: Crki ...nisam igrao Travian al ovde na ikariam masu ljui jeste i kažu svi da je ikariam bolji a pritom nema vremenskog ograničenja trajanja servera
                        Ja počeo...
                        A zašto rušiti postojeći grad, ako gradim novi?
                        Da li da ulazim u neki savey u po;etku ili da čekam?!
                        Da osnujemo mi CBC savez?
                        • BaneT
                          • 09.12.2005
                          • 562
                          CBC savez postoji ali nema veze sa ovom našom pričom.......skraćenica je od Svetosavci.
                          ovo oko gradova........dižež taj grad koji imaš kako bi više resursa vukao iz strugare i rudnika...kada budeš imao uslov da napraviš novi grad, napraviš ga blizu mene da mogu da ti pomognem. Onda ojačaš taj novi grad i srušiš onaj prvi jer je mnooooogo daleko i odmah napraviš još jedan koji je blizu ovog drugog....blizina gradova je veoma važna kao i blizina saveznika.....napadača uvek imaš.......sa nekima možeš da pričaš a nekada jednostavno puška mora da radi.
                          za sada nema potrebe da ulaziš u savez.....jačaj sam pa onda uđi.
                          Svačega tu ima...mene je rokao savez iz top 10 a ja nisam hteo da mešam svoj savez, al je to bilo zezanje.
                          Pročitaj prvo dobro pravila
                          i samo pitaj....tu sam.
                            Ok, potrudiću se!
                              - 42 -
                              • 03.02.2005
                              • 2235
                              • Citroen
                              Ja još uvek nisam uspeo da se registrujem , kako se igra ponaša kad upadneš u sred igre (baš taj deo da nema restarta, kod traviana vredi ako kreneš prvi i igraš maksimalno dnevno vreme), u travianu sam se lepo igrao i klao sa par okolnih naselja, a onda su neki imbecili u 4 napada cca 15 minuta sravnili sve što je dva meseca građeno i jednostavno nisam više imao volju da išta počinjem. (klan te proglasi za farmu i onda svi napadaju zbog resursa i toliko te crpe čak i da imaš volju nema svrhe kad te urnišu svaki krug.)
                              11.04. 0:12 #2
