Golf 2 GTI 16V
  • Kale HGT
    • 27.09.2007
    • 78
    • Zvornik RS
    NAPALJENI KLINCI!!!
    A da ti mozda diskovi nisu keramicki, ili su oblozeni u karbonsko kuciste?
    Decko ako vec hoces da nesto slazes da bi ispo "faca", prvo se malo raspitaj pa tek onda iznesi cinjenice koje mogu biti tacne a ne da ovako odvaljues!!!
    Imao sam golfa koji je mnogo jaci od tvog i nije imao nikakvo hladjenje prednjih diskova!!!
    Evo ti primera: Golf 2 GTI 16V 103KW
    I jos nesto ugradnja tako neceg jeste moguca ali iskljucivo naknadno i to u model sa dubokim branikom kao ovaj (sto kod tebe nije slucaj)
    The final factor that can often make a noticeable difference is cooling. Several companies offer various brake cooling-duct systems which pipe cool air to the disc - If you have a big bumpered car there are kits available to go in the fog light apertures which come supplied with all of the necessary pipework. These kits work by prolonging the time it takes before the brakes get too hot and begin to 'fade'. A good rule of thumb for mildly uprated brakes is: under hard use - the cooler the better. NB. This is sometimes not the case with exotic brake pad compounds so you'd do well to experiment. It is also worth bearing in mind that open spoked alloys are always going to let more air to the disc than standard steels or 16v bottle-tops...
    P.S. I mogao bi malo da povedes racuna o svom recniku, mislim topic si ti otvorio ali nemas pravo da zabranis nekom da ucestvuje u njemu!!!
    ItalianDesign
    • zverko
      • 19.08.2005
      • 7084
      hih, sta sad da napisem a da me ne shvatis pogresno...
      vidi, nemam nameru da se svadjam ili prepucavam sa tobom samo, suvise vremena sam proveo hebavajuci se oko stvarcica na autu koje ti tek treba da radis tako da to sto ti imas da napises meni nije zanimljivo. necu pisati, samoooo, mojne da lupas, mnogo ljudi cita ovo pa ce neko da ti se smeje. izigravas nekog tjunera a ne znas osnovne stvari a da ne ispadne da ti ja nesto tu kao drzim predavanje imas brate mili google pa procesljaj malo, informisi se. nije tuning spojler na kome je neki ljaljo iz kushkundaljeva izbushio rupe sa namerom da u njega stavi maglenke pa nije mogo da nadje odgovarajuce. kladim se da nisi znao razliku izmedju KR i PL usisne dok ti kani nije reko, nisi ni merio svoju. nemam ja nista protiv da ti mislis to sto mislis samo zivis u zabludi. kapiram da svi koji bar jednom sednu u GTI misle da sve znaju o njemu samo to nije uvek tako a tkvi obicno sa tim istim GTijem zvrse ili nekom u gu*ici, ili u banderi ili na krovu...
      • neshaoct
        • 18.08.2007
        • 1754
        • Beograd, Rakovica
        ...Kao sto neko vec rece - Napaljeni klinci....
        Ali skoro 300000 km-a ''bez znaka umora''....i '' cak mu deluje da je s'vremenom sve brzi ''...
        Ove recenice bi trebalo da se stave na deo foruma koji je ionako posvecen ''takvim'' izjavama...
        • Darko_NS
          • 02.12.2004
          • 557
          • Srpska Atina
          s obzirom da poznajem vlasnika.. stvarno dvojka je u izuzetnom stanju iako je presla toliko kilometara, vozio sam se vise puta u njoj, ide fenomenalno, po meni medju nekoliko najboljih i najbrzih dvojki u ns a i sire
          • achilles
            • 23.01.2005
            • 50
            zverko i ko vec... dvojku imam 6 meseci (koliko ima da mi je cale dao) i o njoj nisam nista znao! ama bas nista! Polo mi je u servisu ubacujem mu VR6 pa uzeo dvojku! znaci, nisam znao ni sta je K-glava (a sad je sam cackam) ni da postoji KR, 9A ni PL! ali sam zato momak koji jako brzo uci i za ovih pola godine sam jako puno toga i naucio i uradio! a to je da je ovaj momak koga ste napali (ja) napravio po recima drugih najbrzi gti 16v u ns (gledali su mi zadnju tablicu i GTI-jevi i VTS-ovi i CRX-ovi)! no, nisam dosao ovde da izigravam kvazi tjunera, ovde sam dosao da jos ucim, da postavljam pitanja i trazim pomoc a ne da me tu neko spopada za je8eni spojler da li ima ili nema usisnike i da se tu neko hvata za izjavu "300.000 i sve je brzi"! pa i jeste brzi, mislim...cinjenica je da je sve brzi...o boze, pa sta sam mu sve uradio... (a sta? to nije ni bitno bitno da on fabricki nema usisnike za hladjenje diskova) evo da moja prica ne bude neproverena, ako neko hoce da se uveri slobodno nek me kontaktira na pp pa cemo da organizujemo neko potezanje za to sam uvek raspolozen!
            a da sam napaljeni klinac....pa bas i nisam ali na brzinu jesam! pa kad se vidimo na stazi tu mi se u lice moze sve reci ja vise volim tako! imam pametnija posla nego da kuckam ovoliko teksta!
            a sad da se vise ne svadjamo! prioritet mi je nalazenje usisne 50mm!
            • zverko
              • 19.08.2005
              • 7084
              ma svaka tebi cast nego ocu da ti kazem da to sto radis nema veze sa vezom, mislim na te usisnike osim ako nemas neko ultra kocenje i motor od 300ks. a to naj brzi GTI i te munje zaboravi posto svi znamo kako taj auto ide ili moze da ide. izgleda ti nisi natrco na pravog CRXa ili ne daj boze VTS 16v. nego daj neke detalje oko ovog VR6 pola, to mi zvuci zanimljivo... daj neke slike neki detalj.
              e da, mojne da cackas K glavu posto mnogo veci znalci od tebe se ne usudjuju da je cackaju a oni sto su je cackali uglavnom su je shebali...
              • Sasha
                • 4126
                Tema je golf gti. Sav off je obrisan
                www.arcs.org.rs/forum
                • M@rio
                  • 13.07.2007
                  • 166
                  • Čačak-Beograd(studiram)
                  Sa kojima si stao na crtu verovatno nisu hteli da zizche masinu.Takvih ima mnogo nemoj da te cudi.Desavalo mi se.A sto se tice K glave NE PIPAJ dok je ispravna!!!
                  If you have no lag, you have no turbo.You also have no huge torque increase to look forward to.
                  • pitatore
                    • 11.01.2005
                    • 242
                    Htedoh da te pitam,kazes stavio si skracenje na menjacu, pa me interesuje kako i od cega je skracenje ako nije serijski 2Y menjac?
                    Pleh Hirurgija
                    • shonegti
                      • 30.06.2006
                      • 58
                      zalim da se nadovezem na pricu o usisnicima za hladjenje kocnica. vecina automobila ih ima pa i 316i e36 iz 91. problem je verovatno u tome sto je jako malo gti-a sacuvano u fabrickom izgledu i opremi. 8v ima taj spojler zatvoren, a 16v otvoren. ne znam sta je sporno sa zverkom. trebao mu ili ne usis za hladjenje ima ga i to je jedino tacno. ja sam 6 godina vozio 16v 88 godiste (znaci uski branik) i nemoram da naglasavam da sam ih imao.
                      • neshaoct
                        • 18.08.2007
                        • 1754
                        • Beograd, Rakovica
                        ...shonegti, idi na ovaj sajt :
                        Procitaj i pogledaj sve sto je tamo...
                        Tako izgledaju usisnici za hladjenje kocnica, i sta je sve iza tih ''rupa''...Nisu dovoljne samo rupe, narocito ne na tom mestu...
                        • shonegti
                          • 30.06.2006
                          • 58
                          meni idalje nije jasno sta je sporno. od otvora idu tuneli ka tocku. na m5 i m6 je ista prica. da li treba da stavi neke ventilatore pa da bude priznato da sluze za hladjenje kocnica? nije mi jasna svrha linka. golf dvojka gti 16v sigurno nije primer najsavremenijih i najboljih resenja. taj auto je star preko 20 godina, a i nije nesto narocito brz.
                          • zverko
                            • 19.08.2005
                            • 7084
                            daj mi jednu sliku odozdo gde se vide ti tuneli. ima M5 i M6 ali njima to treba, G2 GTI 16v to ne treba.
                            • shonegti
                              • 30.06.2006
                              • 58
                              sta je tvoje pitanje: da li mu trebaju ili da li ih ima?
                              ne znam zasto bih ja jurio slike za tebe. istrazi malo i pojacaj svoje znanje o gti-u.
                              • zverko
                                • 19.08.2005
                                • 7084
                                moje pitanje je zasto nesto tvrdis kad ne mozes da dokazes. a sto se GTI i znanja o njemu tice ... prevaziso je zverko GTI poodavno a posto si ti shonegti, slikaj svog pa nam dokazi da smo neznalice. ja i dalje tvrdim, fabricki to ne postoji ni na jednoj ediciji GTI MK2.
