Dampf Kraft Wagen
    Nek je sa srećom union
      Slika govori više od 1000 reči, znači da je auto skroz pogodan za transport
      • b_samardzic
        • 1557
        samo opusteno.
        Podmetnu kolica i resen transport
          spisak, sta sve nema od opreme
          E0A = No special edition
          7A0 = Without CD changer/CD player
          4UE = Air bag for driver and front seat passenger
          6XD = Exterior mirrors: electrically adjustable/heated
          5SL = Left exterior mirror: aspherical
          5RU = Right exterior mirror: convex (large viewing field)
          1KD = Disc brakes, rear
          J1D = Battery 380 A (72 Ah)
          1ZF = Disc brakes, front (Geomet D)
          1AC = Anti-lock brake system (ABS)
          3FA = Without roof insert (standard roof)
          UA0 = Rear shock absorption
          G43 = Front shock absorption
          5TD = Decorative aluminum inserts
          7X0 = Without park distance control
          4R4 = Power windows with comfort operation andcircuit breaker
          F0A = No special purpose vehicle, standard equipment
          8GU = Alternator 140 A
          0YE = Weight range 5 installation control only, no requirement forecast
          L11 = Suspension range 11 installation control only, no requirement forecast
          T53 = 4-cylinder gasoline engine 1.6 L unit 06A.S (aluminum)
          3NZ = Rear seat bench unsplit, backrest split folding
          8BB = Halogen headlight for driving on the right
          U1A = Instrument insert with km/h speedometer,clock, tachometer and trip odometer
          X7Y = National sales program export (other)
          1N3 = Speed-related variable steering assist (Servotronic)
          1MR = Leather steering wheel
          8Q1 = Headlight-range adjustment
          9Q0 = Without multi-function display/ on-board computer
          8Z5 = Not hot country
          MW6 = 4-cylinder gasoline engine 1.6 L/75 kW with multi-point injection base engine is T0B/T53/TC3/TL2
          7Q0 = Without navigation device
          CR2 = Cast alloy wheels 6.5J x 16
          7K0 = Without tire pressure warning light
          4X1 = Side air bag front
          3L3 = Manual height adjustment for front seats
          4KC = Side and rear windows in heat-insulatingglass
          3Y0 = Without roll-up sun screen
          4K4 = Radio remote controlled central locking
          5D1 = Carrier frequency 433.92 MHz-434.42 Mhz
          1SA = Without additional front underbody guard
          UG0 = Without hill hold control / hill descentcontrol / comfort driving assist
          0GG = Emission standard EU4
          QG1 = Service interval prolongation
          4GP = Windshield in heat-insulating glass withsunshield and viewing window for vehicleidentification number
              Pa sad neka kažu kako je problem ubaciti bebu u auto
                gepek, kao da je pravljen po meri. I zvucna izolacija gepeka nije uopste losa.
                  Pa to, ko će je slušati do mora, nek se tamo dere za sebe
                  Brate neko bi u Švedskoj za ovu izjavu oduzeo dete
                    sta te briga, nek' ga vode
                      Vidiš, nije mi palo na pamet odmah a dobra ideja
                        zena ne bi pricala sa tobom dva meseca i posle sve po starom.
                          Sve me više zagrevaš za ideju, dvostruki dobitak
                          Dok ne pročita pa onda
                            posto nemam sta da pisem o audiju aj bar da vodim dnevnik potrosnje, po rezervoarima.
                            1. 7.65
                            2. 7.68
                            3. 8.05
                            4. 6.88
                            5. 6.98
                            6. 6.85
                            7. 8.22
                              Dosadan auto, lepo sam ti reko da kupiš Alfu, zabava za celu porodicu
                                Crk'o termostat.
