Integra Type R
  • DC2R
    • 06.12.2005
    • 334
    • Perth Australia
    Integra Type R
    Evo mog prevoznog sredstva (neki su verovatno vec videli na fandjo ali nema veze)
    DC2 Integra standard specs:
    Engine: B18C7 1.8L DOHC VTEC, 141kW@7,900RPM
    Specific: CR 11:1, Cutout@8,500RPM
    Drivetrain: 5 speed close ratio, Limited Slip Differential (LSD)
    Weight: 1,087Kg
    Brakes(F/R): Ventilated Disks xx mm / discs, ABS
    Suspension(F/R): Double wishbone/Double wishbone
    Handling: Rear sway bar (22mm), front sway bar (24mm), front upper strut brace, rear tower brace
    Standard features: Airbags, power windows/steering/mirrors, Recaro buckets seats, Momo leather steering wheel, titanium shifter
    Additional Info: VTEC engagement@5700rpm
    Ja imam Xforce 4-1 headers (izduvne grane iz motora), ostatak auspuha 2.25" sa cannon mufflerom i Apexi air intake
    Na dyno sam dobio 139.1hp na tockovima a najbolje 1/4 mile vreme 15.03 (mada to mora ici i bolje)
  • DC2R
    • 06.12.2005
    • 334
    • Perth Australia
    a ovo mi je od buraza auto
    Car info:
    Nissan Skyline R33 (93 model)
    Engine is 2.5L in line 6 turbo with 5 speed man gear box.
    Mods:
    HKS BOV, 3inch Jasma exhaust, Full body kit (trust front bar, side skirts and GT-R wing), 18inch BBS rims with 235/40 rubbers, lowering springs and upgraded suspension, custom interior (red and black leather).
    Stvari koje su ugradjene na auto ali se nevide na slikama posto su slike malo stare:
    Big intercooler, KN air intake, Apexi boost controler, Apexi SAFC II, dump pipe.
    Na dyno 263hp na tockovima a najbolje 1/4 mile vreme 13.7
    • Deki
      • 18.02.2005
      • 316
      Lepo.
      Jedino volan ...
      • starac vujadin
        • 27.08.2005
        • 2617
        • Stari grad
        Mugen, vozis fantastican auto. Koliko vidim nalazi se u serijskom i u odlicnom stanju bez glupih kich detalja. Uzivaj i ne vozi polako!
        • RS-6
          • 24.07.2005
          • 581
          • Montenegro-Bar
          • 2x AR I BMW 330XI
          Honda je VRH samo ima manu sto joj je volan na pogresnoj strani.
          http://www.youtube.com/watch?v=YCIIW...&feature=feedu YAMAHA
          • 156V6
            • 415
            • BEOGRAD
            Svidjaju mi se sedista u Hondici...a i onih 10k rpm mocno vrti se ko zujalica
              Mnogo je presla ta Integra. Hoce li izdrzati makar jos 300 000?
              • overspeed
                • 24.05.2005
                • 2779
                • Kosovska Mitrovica
                Vec vidjeno - jeste... Ali dobrog auta nikad da se chovek dovoljno nagleda
                Znachi, auto je xtra... A nishta vishe ne volim nego kad na obrtomeru skala ide do 10000 rpm
                Shta reci... Jedino: uzhivaj u vozhnji
                http://www.bmw.tv
                • DC2R
                  • 06.12.2005
                  • 334
                  • Perth Australia
                  Hvala za lepe komentare
                  Sto se tice volana mozda bas ne izgleda nesto na slici ali perfektno lezi u rukama, takodje ima air bag tako da ga nemogu menjati ali nema ni potrebe, ipak je to "momo"
                    Vrh, vrhova. Sve pohvale za porodicne automobile.
                    A volan je meni extra.
                    • srdjan_p
                      • 01.12.2004
                      • 1915
                      • ZR
                      Ja sam ti na fandju rekao svoje misljenje za auto...
                      "The power of dreams - HONDA"
                      • -Vedran-
                        • 03.10.2004
                        • 3255
                        I ja isto...znamo se josh sa VG
                        Power of dreams !!!
                        • Skyline GT-R
                          • 13.02.2005
                          • 806
                          • Chicago - My Kind Of Town
                          Meni je takodje volan strava.Bas je sportski.....ne menjaj ga.
                          A kao fanatic Skyline-a.....gledam i divim se....i nadam se...vama je lako.Jedina zemlja na svetu (pored japana) koja je imala pravo prodaje\uvoza Skyline-a.Sa kim god sam pricao iz autralije, svi zivo voze (ili znaju nekog ko vozi) Skyline-a.Prosto sam steko utisak da svaki drugi racer vozi Skyline.Sta da kazem...ljubomoran sam...
                          Imate li planove daljeg tuning-a?Pogotovo za Sky-a?
                          • Dutchman
                            • 741
                            • Vracar centar sveta
                            Ma volan je extra samo na pogreshnoj strani
                            Prevelika slika u potpisu!
                            • DC2R
                              • 06.12.2005
                              • 334
                              • Perth Australia
                              Imamo i jedan i drugi planova, buraz planira da stavi veci turbo, sportsko kvacilo (heavy duty, nesto od extreme proizvoda) i short shifter.
                              A ja planiram TODA Spec B cams (celi kit sa cam lifters, cam gears itd), novi izduvni sistem (5zigen) i Apexi komp (Apexi Power FC sa hand controler), sportsko kvacilo (isto nesto od extreme proizvoda ali to kad mi ovo ode) i Tein suspensiju (kad ova bude za menjanje)
                              Trebace mi malo duze da sve ovo uradim ali tek sam uzeo auto tako da ima vremena, za 2006 planiram izduvni sistem i Apexi komp, ako budem mogao jos nesto bice super ali neverujem posto dolazim na godisnji odmor tu u srbiju tako da tesko da cu upeti jos mnogo toga da uradim.
                              Cams ce mi biti zadnje posto njih kad budem radio dacu da mi sve urade u kompletu sto ce biti nekih $4500-5000, ali moram prvo da skupim lovu
