prevod
    prevod
    Pošto od moderatora i ostalih niko ne zna dobro engleski, treba mi pomoć Brojeve i putanje do fajla ne treba prevoditi
    Imal ko da je voljan
    The tyrestore Upsize calculator for your tyres
    Well if all that maths seems a little beyond you, and judging by the volume of e-mails we get on this subject, we've made a little Javascript application below to help you out. Select the tyre size you currently have, and then the size you're interested in. Calculate each tyre size and then click on the Click to calculate the difference button. It will show you all the rolling radii, circumferences, percentage differences and even speedometer error. Happy Upsizing!.
    145 155 165 175 185 190 195 205 215 225 230 235 245 255 265 275 285 295 305 315 325 335 / 30 35 40 45 50 55 60 65 70 75 80 82 85 100 R 12 13 14 15 15.5 16 16.5 17 18 19 19.5 20 21 22 23 145 155 165 175 185 190 195 205 215 225 235 245 255 265 275 285 295 305 315 325 335 / 30 35 40 45 50 55 60 65 70 75 80 82 85 100 R 12 13 14 15 16 16.5 17 18 19 19.5 20 21 22 23
    [IMG]file:///D:/cbc/images/downarrow.gif[/IMG] [IMG]file:///D:/cbc/images/downarrow.gif[/IMG]
    Current RR:mm New RR:mm
    Current circumference:mm New circumference:mm
    [IMG]file:///D:/cbc/images/downarrow2.gif[/IMG]
    Difference in circumference:mm or %
    Tyrestore recommends an Upsizing only if the difference if less than 2%
    So when your speedo reads 70mph, you're actually travelling at mph
    A Speedometer error means an odometer error too.
    It stands to reason that if you change the rolling radius of your wheels and tyres, and the speedometer no longer reads correctly, that your odometer will also gradually become inaccurate. Assume for example that you bought a car brand new and changed the wheels and tyres on day one from 195/65R14 to 205/50R15 - not an uncommon change. By the calculator above, that makes your speedometer over read by 1.7%. Consequently, the registered odometer reading will also be out by the same value. So for example, when you get to 10,000km of driving (in the real world), your odometer will actually read 10,170km. OK so that's not a huge difference but it is one of the reasons why most car dealers have a disclaimer on their secondhand vehicles telling you that they won't guarantee the displayed mileage. ("Clocking" the odometer is the other reason). Odometer errors due to mis-matched tyres and wheels will happen on regular odometers as well as the newer digital ones.
    Ako vam se sva ta matematika čini komplikovanom, a sudeći po broju pristiglih mailova sa ovom tematikom koju smo dobili, pripremili smo malu javascript aplikaciju da bi vam pomogla u izboru. Izaberite dimenziju pneumatika koju trenutno posedujete, a onda dimenziju koja vas interesuje. Izračunajte svaku pojedinačnu dimenziju i pritisnite dugme Pritisni za izračun razlike. Izračunaće vam rolling radii, obim, procente odstupanja pa čak i grešku brzinomera. Srećno povećanje dimenzija!
    Evo na brzinu prvi deo!
      Tyrestore preporučuje povećanje dimenzija samo ako je razlika manja od 2%.
      Kada vaš brzinometar pokazuje 70 milja na čas vi zapravo putujete (nešto drugačijom brzinom) mph
      Brzinometar greši znači da i kilometar sat greši
      Razumljivo je da ako promenite radijus vaših točkova (felni) i guma i vaš brzinomer više ne pokazuje pravilno i da merač pređenog puta postaje netačan. Pretpostavimo npr. da ste kupili potpuno novi auto i da ste jednog dana promenili pneumatika sa 195/65Р14 na 205/50Р15 što je česta promena. Kalkulator od malopre izračunao je da vaš brzinometar pokazuje 1,7% više. Shodno tome i merač pređenog puta pokazuje isto odstupanje. Tako da kada pređete 10.000km (u realnom svetu) vaš kilometar sat će pokazati 10.170km. U redu, to i nije velika razlika ali je jedan od razloga zašto većina auto dilera imaju klauzulu da neće garantovati prikazanu kilometražu. ("Nameštanje" km-a je drugi razlog).
      Greška kilometar sata zbog pogrešno usklađenih guma i felni biće i na analognom brojčaniku kao i kod novih digitalnih (pokazivača).
      Isto na brzinu, drugi deo.
      • Hermes
        • 14.02.2006
        • 1309
        • bemve
        Ako te ne zanima prevod radi prevoda samo, ovo ce ti koristiti
        Alloy Wheel & tyre fitment calculator - it calculates inset, poke, speedo error, tyre stretch and loads more.
        • Franjo
          • 14.08.2009
          • 2831
          • Inđija - Beograd
          • Renault megan II res
          Potkrala se neka greška u proračunu, jer se u stvari, u navedenom primeru, radi o smanjenju dimenzija: promer i obim gume (bitnih za izračun brzine i pređenog puta). I to, promer za -23 mm, ili -3.78%. Niskoprofilna guma.
          Adekvatna zamena bila bi 205/55R15, jer je razlika samo -2 mm.
          Ali, Dora nije dao objašnjenje, da li je ova tema samo prevod - radi prevoda? I, zašto baš taj kalkulator, kojeg uzgred, nisam uočio o kojem se radi?!
            • Franjo
              • 14.08.2009
              • 2831
              • Inđija - Beograd
              Kalkulator je sasvim O.K., jer je rezultat razlike između navedenih guma:
              So when your speedo reads 100Km/h , you're actually travelling at 96.21 Km/h
              Znači, lažu (brzinomer i odometar) za + 3.79%
                Molim te da mi objasniš o čemu ti pričaš?...
                • Franjo
                  • 14.08.2009
                  • 2831
                  • Inđija - Beograd
                  Pa, već sam rekao, ako je samo prevod, radi prevoda, tada imaš korektne prevode. I dalje nije jasno, otkud mu ona razlika od 1.7%, kad je naveo, za primer, one dve dimenzije?!
                  A, što se samog kalkulatora tiče, jednostavniji je onaj, naveden u temi o gumama: nema dugmića "calculate" i odmah izbacuje rezultate.
                    Zabrinjavaš me polako... Onaj drugi je tamo negde a ovaj prvi je na našem sajtu. Primer koji je dat je takav kakav je, nemam pojma šta te muči ali matematika je tačna..
                    • Franjo
                      • 14.08.2009
                      • 2831
                      • Inđija - Beograd
                      Matematika je tačna, ali primer nije za navedene dimenzije. Ako zameni 195/65R14 sa 205/50R15, čiji su promer i obujam za 3.78% manji, kada odometar pokaže, da ste prešli 100 km, realno ste prešli 103,78 km.
                        Nemojte samo glasnika (prevodioca)
                        Franjo je u pravu. Primer je pogrešan. Kalkulacija nije tačna
                        U saglasju sa tekstom bi bio prelaz (npr.) sa 185/65R14 na 205/55R15 (takođe česta pojava).
                        Pozdrav!
                          Tekst je glup ali tak oej tamo pisalo (gde sam mazno) Uglavnom malo smo mrdali mozgom a biće i bolje, napravićemo tematski ovakve stvari za sve što se može.. Gume, felne, druge mere itd...
                          Ko nadje nešto pametno neka pošalje link kad mu se nešto svidi
