Zavoli prekidač
Re: Zavoli prekidač
Taj podatak bi imeni posluzio, ja sam jednom uspeo da dovedem isti u mod za programiranje ali sad nemam pojma kako sam to uradio, znam da sam drzao dugme i davao skidao kontakt i ne znam sta sam mu uradio tacno.UGRADITE PLIN DA VAM AUTO PALI KAO VOJNI MAGACIN!
Devojka moze da bude sa sela ali auto MORA da bude iz Nemacke!Comment
Re: Zavoli prekidač
Rešeno, sve je opisano ispod.
To change the setting of the switch, follow the steps described below; please remember
that to end the programming in the correct way, the listed steps must be carried out in
sequence. In case the button is not pressed in the correct sequence or times, the setting
procedure is deactivated, thus returning to the previous setting.
PHASE 1 - start the car by keeping the button pressed.
PHASE 2 - the TWO-COLOUR LED (RED-GREEN) starts to blink; keep pressing
the button until the TWO-COLOUR LED blinks only in RED, then release the button.
At this point, the TWO-COLOUR LED starts blinking in GREEN.
PROGRAMMING OF THE TYPE OF SENSOR
PHASE 3 - the TWO-COLOUR LED blinks in GREEN while the switching on of one of the
other LEDs indicates the type of level sensor that is currently stored. By means
of a short button pressure, it is possible to change the type of level sensor:
YELLOW LED ON - A.E.B. sensor;
GREEN LED 1/4 ON - 0÷4700 Ohm sensor;
GREEN LED 2/4 ON - 0÷90 Ohm sensor;
GREEN LED 3/4 ON - RESERVE sensor.
To shift to the following setting, keep pressing the button for 3 seconds.
PROGRAMMING OF THE CHANGE WHILE ACCELERATING OR DECELERATING
PHASE 4 - the TWO-COLOUR LED remains ON only in GREEN, while the switching on of
the YELLOW LED or of the GREEN LED 1/4 indicates whether the switch is programmed
for the change while DECELERATING or ACCELERATING.
By shortly pressing the button, it is possible to change this option:
YELLOW LED ON - commutator with change while DECELERATING;
GREEN LED 1/4 ON - switch with change while ACCELERATING.
PROGRAMMING OF THE REVOLUTION REFERENCE FOR THE CHANGE
PHASE 5 - The TWO-COLOUR LED remains on only in RED, while the YELLOW LED
indicates the setting of the RPM reference for the change:
YELLOW LED blinking - engine RPM lower than the reference for the change;
YELLOW LED ON - engine RPM higher than the reference for the change.
Start the car and bring the engine at the RPM at which you wish the change to take place;
the YELLOW LED blinks if the engine RPM are lower than the reference for the change,
otherwise it remains on. Whenever you press the button, the engine RPM (provided they
are null) are stored like new reference for the change.
Keep pressing the button for 3 seconds; after this, the TWO-COLOUR LED starts to blink
in RED-GREEN to indicate the completion of the programming procedure.
At this point, disconnect the 12 Volt ignition.Comment
