Odg: atest TNG-a
17.6.5. Gas-tight housing on the container
17.6.5.1. A gas-tight housing over the container fittings, which fulfils
the requirements of paragraphs 17.6.5.2. to 17.6.5.5. shall be
fitted to the fuel container, unless the container is installed
outside the vehicle and the container fittings are protected
against dirt and water.
17.6.5.2. The gas-tight housing shall be in open connection with the
atmosphere, where necessary through a connecting hose and a
lead-through.
17.6.5.3. The ventilation opening of the gas-tight housing shall point
downwards at the point of exit from the motor vehicle.
However, it shall not discharge into a wheel arch, nor shall it
be aimed at a heat source such as the exhaust.
A za ovo ima razloga.
lead-through.
