BMW Bordcomputer
  • BMW Z3
    • 22.10.2005
    • 27
    • Podgorica
    BMW Bordcomputer
    Ako moze pojasnjenje za ovaj skriveni meni kod BMW-a i pogotovo kako da prebacim sa L_on na L_oFF evo i adrese toga sto ja hocu (na njemackom)
    A evo i toga na Engleskom:
    Instructions to access the hidden OBC functions:
    1. Hold Trip Reset while turning ignition key to on position
    2. OBC should show "Test"
    3. Use Trip Reset to select function 19.0 that unlocks all the features
    3. Wait for display to show "Off"
    4. Depress Trip Reset for 1/4 second and release it
    5. With no delay press Trip Reset several times to select one of the following function s
    BMW E46 On-Board Computer (OBC) Hidden Codes
    nr example description
    1 Car Engine and cluster data
    1.0 46nnn Chassis nr/VIN serial number (last 5 digits)
    1.1 4nnn K-number
    1.2 690236 Cluster Part #
    1.3 045210 Coding (04)/diagnosis (52)/bus index (10)
    1.4 1200 Week (12)/year of manufacture (2000)
    1.5 09_160 Hardware (09) and software # (16.0) of cluster
    1.6 Not used
    1.7 04__44 CAN-version (04) KI-revision index (44)
    2 (test) Cluster System Test - Activates the gauge drivers,
    indicators and LEDs to confirm function
    3 SI Data
    3.0 1098 Used fuel in liters since last SI (Service Inspection)
    3.1 0231 Periodic inspection days; elapsed days (since last SI)
    4 Momentary Consumption
    4.0 0145+ Instant fuel consumption - 0145=14.5 liters/100km
    4.1 0018 Instant fuel consumption - 0018=1.8 l/Hour
    5 Distance Gone Consumption
    5.0 082 Average mileage; 082=8.2 liters/100km
    5.1 0536 Calc. km to refuel (momentary distance to go)
    6 Fuel Level sensor inputs in liters
    6.0 109330+ Fuel level averaged; Left half sensor input=10.9 liters; Right sensor input=33.0 liters
    6.1 0439+ Total tank level averaged; vlgs 6.0: 10.9+33.0=43.9 liters
    6.2 0442+ Indicated value (44.2) and tank phase
    7 Temperature and Speed
    7.0 021+ Coolant/Engine temperature (2.1C)
    7.1 130 Ambient/Outside temperature - chg met 5 pts. 125/130/135
    7.2 + Engine speed / Current RPMs 1/min
    7.3 + Vehicle speed / Current Speed in km/hour
    8 Input value in HEX form
    8.0 1d0+ System voltage ADC-Value Hex code
    8.1 26C33C+ ADC Values HG left/HG right
    8.2 0000 ADC Value brake degradation sensor (000=o.k.)
    8.3 18C ADC Value outside temperature
    9 Battery
    9.0 140 Battery Voltage - 140 = UB 14.0v
    9.1 242013+?
    9.2 074_78+?
    9.3 0011+?
    10 Not used
    11 Not used
    12 Not used
    13 GonG Gong Test
    14 Not used
    15 Status cluster I/O-ports (bit codes) 0=low; 1=high
    1st-belt contact, seat belt fastened=0; 2) ignition lock contact, key inserted=0; 3) door contact, door open=0; 4) clock button pressed=0; 5) SI reset=0, for reset=0; 6) EGS transmission failure=0
    Status Digital Outputs (bits) 0=inactive, 1=active
    1) Gong output; 2) Brake warning lamp; 3) Low fuel warning lamp; 4) EGA lamp; 5) seat belt lamp; 6) manipulation dot
    16 Not used
    17 Not used
    18 Not used
    19 Lock Status; unlocks functions in range 3-18
    19.0 L-On/L-Off Unlock: press button when "L-Off"
    20 Not used
    21 Software Reset; reset OBC settings
    00 End of test
    • BMW Z3
      • 22.10.2005
      • 27
      • Podgorica
      Hvala ti ali nasao sam sinoc sa 15 opcija toje za
      IC (instrument cluster) tests 1-15
      1995 - 1998 (99) 318ti
      1996 - 2000? Z3
      1997 - 1999 E36 4dr/coupe/convertible/M3
      a evo i pojasnjenja opcija
      Step 1: Press and hold the mileage reset button.
      Step 2: Put key into ignition switch and turn to KLR (Ignition switch
      position #1)
      Your LCD display will show something like this "tESt 01"
      Step 3: You will need to unlock the test function first so when the LCD
      Display shows "tESt 01," press the reset button till you get to "tESt 15."
      Once you're on test 15 press, and hold the reset button for a few seconds
      until it displays "off." Now you can cycle through the test features. Here
      they are as they follow:
      Test 1: Instrument self test
      1st display: BMW PART NUMBER (6 digits)
      2nd display: CODE NUMBER (5 digits) Internal Coding Plug #
      3rd display: K NUMBER (4 digits)
      4th display: CHASSIS NUMBER (5 digits) this is part of your VIN
      5th display: SOFTWARE VERSION (3 digits)
      6th display: REVISION INDEX (2 digits) Hardware #
      After all 6 displays are finished, an analog gauge test will be performed.
      Test 2: Engine Data - This display is an "engine factor" value that is stored
      in the coding plug. The instrument cluster processor uses this factor in
      addition to the "TD" signal from the DME control module to process and
      display tachometer RPM based on the engine installed. For EXAMPLE:
      *ENGINE FACTOR 2 = 4 CYLINDER
      *ENGINE FACTOR 3 = 6 CYLINDER
      *ENGINE FACTOR 4 = 8 CYLINDER
      Test 3: SI elapsed distance - the total mileage in kilometer since the last
      reset. Which service is due at the next inspection (OIL SERVICE or INSPECTION)
      Test 4: SI elapsed days - no value for US vehicles. Relates to Euro annual
      inspections.
      Test 5: SI evaluation factor - for engine speed and temp. thresholds being
      passed.
      Display: n = 0 or 1. Engine speed (over-rev)
      t = 0 or 1. Engine temp.
      NOTE: "n0" means that you hit the maximum threshold for engine speed and "t1"
      means you overheated the engine. I found out from my instructor that this
      test 5 is false due to software related problems.
      Test 6: Fuel Level and coolant temp. - Display of hexadecimal codes in
      relation to gauge position.
      Fuel gauge ----> Hex value
      A (empty)---------> 0d
      End of reserve---> 37
      B-------------------> 54
      C-------------------> 90
      D------------------> c4
      E (full)-----------> f0
      Engine temp. ----- Hex Value
      A----------------------> ce
      B----------------------> 6d
      C----------------------> 5c
      D (center)----------> 4f-23
      E-----------------------> 1e
      F-----------------------> 18
      Test 7: Engine speed (Digital Tach)- display of current engine speed
      Test 8: Road speed - display of current road speed in km/h
      Test 9 Distance reading - this allows the total stored mileage to be updated
      if one of the storage components has to be replaced. This test step will be
      used if the manipulation dot is illuminated in the cluster display. This
      display will show the component with the lower mileage. For example:
      Display of 012654 l indicates that the mileage in the internal EEPROM is
      lower than the mileage stored in the coding plug.
      Display of 000325 E indicates that the mileage in external coding plug is
      lower then the total mileage stored in the internal EEPROM.
      Pressing the reset button for 4 seconds will over write the lower mileage
      with the higher mileage and cancel the manipulation dot. The SI data will
      also be transferred at the same time.
      Test 10: Status bits (input signals) - the status of digital inputs to the
      cluster are displayed as 0 or 1.
      Display: 0 = input low, 1 = input high.
      _ _ _ _ _ _ <--- Mileage display...6 digits left to right
      1st - belt contact, seat belt fastened = 0
      2nd - ignition lock contact, key inserted = 0
      3rd - door contact, door open = 0
      4th - clock button pressed = 0
      5th - SI reset = 0, for reset = 0
      6th - EGS transmission failure = 0
      Test 11: Status Bits (output signals) - the status of digital outputs is
      displayed.
      Display: 0 = output inactive, 1 = output active
      1st - Gong output
      2nd - Brake warning lamp
      3rd - Low fuel warning lamp
      4th - EGA lamp
      5th - seat belt lamp
      6th - manipulation dot
      Test 12: not used
      Test 13: Country code of cluster - the display indicates the country version
      of the cluster. This cannot be
      changed in the workshop. Display: USA 02
      Test 14: Software Reset - The reset must be carried out if any faults are
      present that are not plausible before any components are replaced. After the
      reset, the system will exit the TEST mode and the lock
      will be reactived.
      Test 15: lock/unlock
