Benzinac ne pali kad je motor topal / vruć
  • nibs
    • 12.10.2015
    • 24
    • Sarajevo
    • Audi
    Evo nakon par dana, auto se ponasa odlicno, dakle mogu donijeti zakljucak da je bilo do tog CTS senzora kojeg je preporucio kostaB
    Isto tako dok sam trazio po Internetu rjesenja, dosao sam do ovog clanka gdje pise, citiram
    "If your vehicle starts to use a lot more gasoline than usual, or black smoke is starting to come from the exhaust pipe, these are indicators that the coolant temperature sensor in your vehicle could be defective, and needs to be replaced. If you start having trouble starting your vehicle after it has reached its normal operating temperature, this is usually a very good sign that you need to have the coolant temperature sensor checked."
    - Upravo se to i dogadjalo, osim crnog dima bio je i bijeli jer je bilo puklo crijevo od motora prema zracnom filteru gdje je auto povlacilo previse zraka.
    Uglavnom, ako bude problema javit cu se jos ovdje.
    I jedno veliko hvala clanu @kostaB
    • kostaB
      • 01.03.2008
      • 44
      • Aleksinac
      • Opel Vectra 1.6i
      Ma bice to sigurno sve ok!
      Nema na cemu,tu smo da pomazemo jedni drugima-to je i svrha foruma!!!
