Carprog 4.01
  • clico
    • 05.05.2014
    • 161
    • petrovac
    • Opel
    Carprog 4.01
    Kolege da cujem vasa misljenja o ovom Alatu . ja ga posedujem i dosta stvari mi odradjuje. Da cujem vasa iskustva???
    CARPROG FULL V4.01
    Funkcije uredjaja:
    1. Make the Universal tool - CARPROG inside have powerful 16-bit MPU and full set of automotive interface drivers. In basic version you will get hardware with extra functions: 12 input/output pins forEEPROM in-circuit programmer, future possibility's to make on the same hardware Microcontroller programmer, Immobiliser Transponder Key programmer with antenna adapter for 125/134 kHz, K-line diagnostic (dashboard odometer programming, immobilizer key programming), CAN line diagnostic,+5V/+12V output, USB, power supply only from USB.
    2. Make the Low Cost tool - with CARPROG basic you will receive many extra functions (like car radio code calculator CC1, EEPROM programmer and VAG dashboard's programmer by CAN) and all additional software's you can buy extra according your need.
    3. Make it User Friendly - Windows XP software, works without any installations, on all PC, use USB to PC link, all adapters schematics diagrams on-line.
    Softver:
    ECU-OPEL - OPEL login reader from motor hybrid ECU. Works with Bosch ME1.5.5, Siemens SIMTEC71, SIMTEC71.1, Delco Diesel, Delco Multec.
    OPEL CAN - Opel ECU by CAN programmer - read/change mileage in EDC16, MT35E, HSFI 2.2 read PIN, reset ECU
    PSG16 - Opel PSG16 diesel pump by OBDII - read/change mileage, read PIN, reset ECU
    OPEC28 - Opel Siemens Simtec ECU Tool Advanced
    Carprog Airbag:
    S5.1 - VAG (Audi, VW, Skoda, Seat) Airbag Reset Tool
    S5.2 - BMW Airbag Reset Tool
    S5.3 - Mercedes Benz Airbag Reset Tool
    S5.4 - FORD Airbag Reset Tool
    S5.5 - GM Airbag Reset Tool by OBDII
    S5.6 - CARPROG CR16 Airbag tool - Audi, Mercedes, Ford, Volvo
    S5.7 - Renault Airbag reset tool
    S5.8 - Peugeot Airbag Reset tool
    S5.9 - Citroen Airbag Reset tool
    S5.10 - Honda Airbag Reset tool
    S5.11 - Audi Airbag reset tool by direct connection to EEPROM or MPU
    S5.14 - Ford Airbag Reset tool by direct connection to EEPROM or MPU
    S5.16 - Hyundai Airbag Reset tool
    S5.17 - KIA Airbag Reset tool
    S5.18 - Lexus Airbag Reset tool
    S5.19 - Rover Airbag Reset tool
    S5.21 - Mazda Airbag Reset tool
    S5.22 - Mitsubishi airbag reset tool
    S5.23 - Nissan Airbag reset tool
    S5.20 - Mercedes Benz Airbag Reset tool by direct connection
    S5.25 - Opel Airbag reset tool by direct connection
    S5.27 - Saab Airbag reset tool by direct connection
    S5.28 - Subaru Airbag reset tool by direct connection
    S5.30 - Toyota Airbag reset tool by direct connection
    S5.31 - Alfa Romeo Airbag Reset Tool
    S5.32 - Fiat Airbag Reset Tool
    S5.33 - Porsche Airbag Reset Tool
    S5.34 - Suzuki Airbag Reset Tool
    S5.35 - Volvo Airbag Reset Tool
    S5.36 - Daewoo Airbag Reset Tool
    3. CarProg Dash:
    S7.1 - VAG CAN programmer
    S7.2 - CarProg Dashboard programming
    S7.3 - CarProg Dashboard programming package update
    S7.4 - Fiat KM correction by OBDII
    S7.5 - Mercedes Benz ASSYST explorer
    S7.6 - VDO dash decrypt tool - Skoda Roomster, SuperB, VW Polo, Audi A3, A6, Allroad with 93C86 odometer change and PIN reading
    S7.7 - Ford odometer change by OBDII (by CAN)
    S7.8 - VW 2007+ by OBD - Golf, Passat, Eos, Touran, Tiguan, Octavia with Micronas by diagnostic
    S7.10 - VAG VDO dashboards by K-line OBDII diagnostic - VW T5, Passat B5, Skoda SuperB and others
    2J74YAUDI - Audi 2J74Y repair software for CarProg
    4. CarProg Immo:
    S4.1 - Toyota Key Programmer
    S4.2 - Lexus key programmer
    S4.3 - Daihatsu Key Programmer
    S4.4 - CarProg BMW Key programmer
    S4.5 - Mercedes Benz Key programmer
    S4.6 - RENAULT Megane/Scenic infrared key programmer
    S4.7 - Kessy tool - A8, Touareg, Phaeton, Cayenne PIN code reader
    5. CarProg Processor:
    S2.1 - CARPROG Motorola (Freescale) HC05 MPU programmer
    S2.2 - CARPROG Motorola (Freescale) HC11 MPU programmer
    S2.3 - CARPROG Motorola (Freescale) HC08 MPU programmer
    S2.4 - CARPROG Motorola (Freescale) 912 and 9S12 MPU
    6. CarProg Programmer:
    ST92 - ST92F120, ST92F150, ST92F250 internal EEPROM programmer
    7. CarProg Radio Code:
    S6.1 - CARPROG CC1
    S6.2 - CARPROG CC2
    S6.3 - CARPROG CCN
    S6.4 - Philips Car Radio decoder
    S6.5 - Renault Car Radio decoder by serial number
    S6.6 - Audi/VW/Seat/Skoda car radio decoding software
    RNS510 - Navigation decoding tool by Navi diagnostic
    ADAPTERS:
    1: CarProg Main harware interface
    2: A1 - OBD2 Adapter Cable
    (Inside have K-line and CAN bus switches. Use with all cars complained with OBDII standard)
    3: D1 - Odometer-airbag Adapter
    (Dashboard ,Airbag programming adapter )
    4: A3 - Transponder Antenna ( Used with all
    CARPROG immobiliser software )
    5: A10 - Motorola Adapter Cable
    (Motorola MCU programing adapter )
    6: A11 - BMW EWS Adapter Cable
    ( Used with BMW Immo software )
    7: A16 - Car radio Cable
    ( Used for Opel, Renault, Peugeot, Citroen car radio made by Philips decoding)
    8: A15 - Cable
    ( Used with D1 adapter ,Universal car dashboard and airbag programming adapter )
    9: A17 - Honda Airbag OBD2 Cable
    ( Adapter for Honda airbag reset by OBDII )
    10: A4 - Eeprom Adapter Cable
    ( Used for eeprom programming)
    11: A5 - DIP8 Clip Cable
    ( DIP8 Clip for eeprom programming)
    12: A6 - SOIC8 Clip Cable
    ( SOIC8 Clip for eeprom programming)
    13: A7 - MB 38-Pin Cable
    (Used with MB Airbag and dashboard software)
    14: A8 - BMW 20-Pin Cable
    ( Used with BMW airbag and dashboard software )
    15: RNS510 Adapter Cable
    ( RNS510 radio decoding interface cable )
    16: VOLVO FORD CAN 2006+ Cable
    (Needed for airbag and dashboard programming)
    17: FIAT CAN 2006 Cable
    ( Needed for airbag and dashboard programming)
    18: C1 OBD2 Female Cable
    19: USB Cable
    20: Power cable
    21: CD
    Ne radi bas sve idealno, ja ga za Opele koristim za iscitavanje Car Passa reset Ecu-a i km. Stipaljke mu nisu nesto extra (smece ) tako reci dali je neko od vas radio i kakva su vam iskustva . Za tokene ne brinem jer moze da se reaktivira ,dali je neko reprogramirao na neku noviju ver. na pr: 4.74 ili noviju.Nije mi problem odraditi ga Abdejtovati...DA CUJEM VASA MISLJENJA I SUGESTIJE??????????
  • zlatkomusa
    • 12.09.2012
    • 11
    • Nova Varos
    pa ja sam ga skoro nabavio a da neznas mozda gde imaju da se kupe malo kvalitetnije stipaljke?a reci mi na opelima kako se sa njim iscitava car pas i na kojim modelima moze da se uradi?kako se sa njim proglasava nevinim racunar u opelu?
    • clico
      • 05.05.2014
      • 161
      • petrovac
      • Opel
      Kolega Stipaljke izbegavaj...Za rad sa Carprogom imas u uputstvu na samom disku!!! Koju Verziju Carproga imas 4XX ili noviju?
      • zlatkomusa
        • 12.09.2012
        • 11
        • Nova Varos
        Pa nabavicu podnozije za citanje epproma.verziju soft imam 4.74 i 6.3
        • clico
          • 05.05.2014
          • 161
          • petrovac
          • Opel
          I kakav je tvoj zakljucak izmedju ova dva softa????Mislim na razlike u radu na pr. 4.01 nemoze da prijavi karticu na Reno-u dok novije ver. mogu...
          Originalno postavljeno od zlatkomusa
          • clico
            • 05.05.2014
            • 161
            • petrovac
            • Opel
            Citaj ih programatorima . Muke su to sa Carprogom i pitanje je dali ce ti uspeti?Ja ne rizikujem a kada vec pominjes podnozja koristi Progrmator u zavisnosti ko i za sta???
