Strana 2 od 4 PrvaPrva 1234 PoslednjaPoslednja
Rezultati 13 do 24 od 42
Tema: Skracenice, pojasnjenja, prevodi
    06.01.2005
    BBgd/Mow
    BPV= by pass valve
    BOV= blow-off valve
    WI= water injection
    CAI= cold air intake
    RAI= ram air intake
    IAT= intake air temperature
    EGT= exhaust gases temperature
    IC= intercooler
    A/A IC= air to air intercooler
    W/I IC= water to air intercooler
    Torsen= tor(que) sen(sitive) differential
    TC= traction control
    BBK= big brake kit
    GTI= Gran Turismo Internazionale (stara italijanska oznaka)
    BSFC= brake specific fuel consumption
    AT= automatic transmission
    MT= manual transmission
    ASC= active stability control
    ECU= electronic control unit
    TCU= transmission control unit
    HID= ksenon, high intensity discharge
    Boost or bust...
    Citirati Originalno postavljeno od Uros Piperski
    AMM - Air Mass Meter
    LPG - Liquid Propane Gas (je l' tako?)
    Petroleum ne propane.
    A/S Air suspension
    AAV Auxiliary air valve
    ABDC After bottom dead centre
    ABS Anti-lock brakes
    AC Air conditioning
    ac Alternating current
    ACE Active cornering enhancement
    ACSD Automatic cold start device
    ACT Air charge temperature (sensor)
    ACV Air control valve
    AEI Integrated electronic ignition
    AGS Adaptive automatic transmission control
    AIV Air induction valve
    AKR Anti-knock control
    Alu Aluminium
    AP Air pump
    APP Accelerator pedal position
    ARB Anti roll bar
    ARF Exhaust gas recirculation
    AS Air suction
    ASR Acceleration skid control
    ASV Air suction valve
    AT Automatic transmission
    ATDC After top dead centre
    AUX Auxiliary drive shaft
    AWD All wheel drive
    13.10.2004
    Novi Beograd, kicblo
    IMO - blokada paljenja
    ILR- unutrasnja lampica
    KBS - kablovska garnitura
    CC - check control
    EKP - pumpa za gorivo
    FH - podizaci prozora
    GBM -indikator loma stakla
    HKL - servo upravljanje
    HZG - grejanje
    MT - mehanicki menjac
    NSW - farovi za maglu
    PBSL - zastitno kocenje pri parkiranju
    AZV - urezaj za vucu prikolice
    & A Check and Adjust
    CA Camshaft
    Cab/Cabrio Cabriolet/convertible
    Cam Camshaft
    CAN Controller area network (data bus)
    Carb-2V Carburettor - twin choke
    Carb-Elec Carburettor - electronically controlled (FBC)
    Carb-FJ Carburettor - fixed jet
    Carb-VV Carburettor - variable venturi
    Cat Catalytic converter
    CB Contact breaker ignition
    CD Constant depression
    CDI Capacitor discharge ignition
    CFC Chlorofluorocarbon
    CFi Central fuel injection
    CIH Cam in head engine
    CKP Crankshaft position
    CMP Camshaft position
    CO Carbon monoxide
    CO2 Carbon dioxide
    Cpe Coupe
    CPU Central processing unit
    Crank Crankshaft
    CS Crankshaft
    CSA Cold starting aid
    CTP Closed throttle position
    CTS Coolant temperature sensor
    CTX Continuously variable transmission
    CVH Compound valve hemispherical
    CVT (1) Continuously variable transmissioin
    CVT (2) Current to vacuum sensor
    BARO Barometric pressure
    BBDC Before bottom dead centre
    BDC Bottom dead centre
    BS Balancer shaft
    BTDC Before top dead centre
    Bus Bus
    d.
    DEE Digital engine electronics
    DHP Diaphragm type feed pump - high pressure
    DI Direct/distributorless ignition
    DIS Digital idling stabilisation
    DLC Data link connector
    DLP Diaphragm type feed pump - low pressure
    DME Digital motor electronics (Motronic)
    DOHC Double overhead camshaft
    DPFE Differential pressure feed back exhaust
    dr Door
    DSTC Dynamic stability and traction control
    DVM Digital volt meter
    e.
    EACV Electronic air control valve
    Eci Electronically controlled injection
    ECM Engine control module
    ECT Engine coolant temperature (sensor)
    ECU Electronic control unit
    EDIS Electronic distributorless ignition system
    Efi Electronic fuel injection
    EFP Electronic accelerator pedal
    EGR Exhaust gas recirculation
    EGS Electronic automatic transmission control
    el Cream
    ELCD Evaporative loss control device
    ELD Electronic load detector
    ELR Electronic idle speed control
    EPROM Erasable programmable read-only memory
    EPS Electric power steering
    EPT Exhaust pressure transducer
    ESA Electronic spark advance
    ESC Electronic spark control
    ESP Electronic stability program
    ETC Electronic traction control
    ETS Electronic throttle system
    ETV Electronic throttle valve
    EVAP Evaporative emission
    EVR Electronic vacuum regulator
    EX/EXHAUST Exhaust camshaft
    EZF/K/L-i/-h Computerised ignition
    f.
    F Cooling fan
    FA Front axle
    FBC Feed-back carburettor
    FL Fuse link
    FP Fuel pump (diesel)
    FWD Front wheel drive
    g.
    GEN Alternator
    h.
    HC High compression ratio
    HD Heavy duty
    HEGO Hot exhaust gas oxygen (sensor)
    HFC Hydrofluorocarbon
    HFM Hot film management
    HO2S Heated oxygen sensor
    HP Hydraulic pump
    HS Hydropneumatic suspension
    HT High tension
    Hyd Hydraulic (tappets)
    Hz Hertz - frequency (cycles per second)
    i.
    /O Input-output unit
    IAC Idle air control
    IAT Intake air temperature
    IC Integrated circuit
    ICE Computerised ignition system
    ICM Ignition Control Module
    ICSV Idle control solenoid valve
    IFS Independent front suspension
    IFZ Infra-red remote control for central locking
    IMA Iding mixture adjustment sensor
    IN/INLET Inlet camshaft
    IP Injection pump (diesel)
    IRS independent rear suspension
    ISB Idle speed boost
    ISC Idle speed control
    ISCS Idle speed control servo
    j.
    Jet. Jetronic
    k.
    KAM Keep alive memory
    Kat Catalytic convertor
    KS Knock sensor
    l.
    Lambda Lambda value (special test equipment)
    LC Low compression ratio
    LED Light emitting diode
    LH Left-hand
    LHD Left-hand drive
    LSD Limited slip differential
    LWB Long wheel base
    m.
    MAF Mass air flow (sensor)
    MAP Manifold absolute pressure
    Map-DI ECU controlled direct ignition
    Map-DIS ECU controlled distributorless ignition
    Map-h ECU controlled, hall effect ignition
    Map-i ECU controlled, inductive ignition
    Mass Mass/hot wire meter
    Max Maximum
    MFI Multi-port fuel injection
    MFI-c Multi-port fuel injection - continuous
    MFI-i Multi-port fuel injection - intermittent
    MFI-s Multi-port fuel injection - sequential
    MIL Malfunction indicator lamp (engine check lamp)
    Min Minimum
    min Minutes
    MLUS Modulated lock-up solenoid
    mm Millimetres
    MMC Manual mixture control
    Mono. Monopoint
    Mot. Motronic
    MPFi Multi-port fuel injection
    MPi Multi-port injection
    MPV Multi-purpose vehicle
    ms Milliseconds - Injector pulse duration
    MT Manual transmission
    MWB Medium wheelbase
    n.
    n ATDC
    N Neutral position, automatic transmission
    N Negative, Wheel alignment
    N (bold) Renew bolts/nuts
    N= 91 octane petrol
    NATS Nissan anti-theft system
    nf Neutral
    Nm Newton metres
    NO Nitric oxide
    NO2 Nitrous dioxide
    NOx Nitric oxide
    NTC Negative temperature coefficient
    o.
    OD Overdrive
    OHC Overhead camshaft
    OHV Overhead valve
    OP Oil pump
    p.
    P Park position, automatic transmission
    P Positive, wheel alignment
    PAG Polyalkylene glycol
    PAS Power assisted steering
    PATS Passive anti-theft system
    PCV Positive crankcase ventilation
    PGM-FI Programmed fuel injection
    PIP Profile ignition pick-up (signal)
    PLA Pneumatic idle speed enrichment
    PMS Pressure management system
    PP Piston type feed pump
    PROM Programmable read-only memory
    PS Power steering
    PT Power take-off
    PTC Positive temperature coefficient
    r.
    R Radial ply tyres
    R & I Remove and Install
    RA Rear axle
    RAM Random access memory
    R-Cat Regulated catalytic converter
    RH Right-hand
    RHD Right-hand drive
    ROM Read-only memory
    RPM Revolutions per minute
    RUF Adaptable to catalytic converter
    RWD Rear wheel drive
    s.
    S= 95 octane petrol
    SACV Secondary air control valve
    Saloon Saloon
    SB Splitter box
    SC Supercharger
    SEFI Sequential electronic fuel injection
    Sep Separate
    SFI Sequential fuel injection
    SLS Self levelling suspension
    SOHC Single overhead camshaft
    sp Number of forward gears
    SPi Single point injection
    STC Stability and traction control
    STO Self test output
    sw Black
    SWA Single wheel axle
    SWB Short wheel base
    SZ Coil ignition (breaker triggered)
    t.
    Tensioner
    TB Torsion bar (Wheel alignment)
    TB Transfer box
    TBI-c Throttle body injection - continuous
    TBI-i Throttle body injection - intermittent
    TC Twin carburettors
    TCCS Toyota computer control system
    TCS Traction control system
    TD Turbo diesel
    TDC Top dead centre
    TPM Tempomat cruise control
    TPS Throttle position switch/sensor
    Trans-h Transistorized hall effect ignition
    Trans-i Transistorized inductive ignition
    TSS Transmission speed shift
    TSZ-h Transistorized ignition - hall effect
    TSZ-i Transistor ignition - magnetic induction
    TWA Twin wheel axle
    u.
    U-Cat Unregulated catalytic converter
    U-Kat Unregulated catalytic converter
    v.
    VAF Volume air flow sensor
    Van Van
    Vanos Variable valve timing
    VEZ Fully electronic ignition
    VICS Variable intake control system
    VIN Vehicle identification number
    VIS Variable intake system
    VP Vacuum pump
    VRIS Variable resonance intake system
    VSS Vehicle speed sensor
    VSV Vacuum switching valve
    V-Tec Variable valve timing and valve lift
    VTV Vacuum transmitting valve
    w.
    W Transverse bolts on main bearing caps
    WOT Wide open throttle
    WP Water pump
    Eto, pa sad vadite oči )
    28.12.2004
    Beograd - Paviljoni(blok 7a)
    TCR - Twin CarbuRator
    TCR - Turbo ChaRged
    "Brano sine , vozi POLAKO..."
    18.02.2005
    GSi - Grand Sport Injection (Opel & co.)
  1. Skracenice
    Od Armageddon ///M u forumu WasteGate (odušak)
    Odgovora: 24
    Posl. poruka: 20.11.2008, 23:13
  2. Prevodi phpBB-a na srpski!
    Od 206 u forumu Aktivnosti CBC zajednice!
    Odgovora: 18
    Posl. poruka: 01.12.2005, 18:00
