Rezultati 1 do 2 od 2
Tema: Aston Martin DB 11
    31.03.2005
    AR 147
    Aston Martin DB 11
    Aston Martin DB11: full technical specifications
    Engine: Front mid-mounted 48-valve, all-aluminium, 5204cc twin-turbo V12. CR of 9.2:1. 600bhp at 6500rpm, 516lb ft from 1500-5000rpm. Electronically controlled exhaust, intelligent bank activation. 115bhp/litre.
    Transmission: Rear mid-mounted ZF eight-speed automatic, alloy torque tube with carbonfibre prop, limited-slip differential
    Chassis: Two-door 2+2, extruded and bonded aluminium structure, cast magnesium door structures. 1770kg dry weight, 51%/49% weigh distribution.
    Suspension: Front independent double wishbone suspension, anti-roll bar and adaptive dampers / Rear multi-link, coil springs, anti-roll bar and adaptive dampers
    Steering: Electric power-assisted rack and pinion with 13:1 ratio, speed sensitive, 2.4 turns lock-to-lock
    Braking: Front ventilated two-piece steel discs (400x36mm), six-piston calipers / Rear ventilated steel discs (360x32mm) with four-piston calipers; electronic parking brake
    Wheels and tyres: Front 9Jx20" Bridgestone S007 255/40 ZR20, Rear 11Jx20" Bridgestone S007 295/35 ZR20
    Standard equipment: Heated memory electric front seats, cruise control, parking sensors, 360-degree camera, dual-zone climate, multiple airbags, keyless entry and start, 400w audio system, sat-nav, DAB, Bluetooth.
    http://www.carmagazine.co.uk/car-new...r-in-pictures/
    Prelep
  1. How not to unload Aston Martin
    Od ///M_Power u forumu WasteGate (odušak)
    Posl. poruka: 19.01.2009, 21:38
  2. Aston Martin db2-db5 kit car?
    Od Bzuva u forumu Kit Cars
    Odgovora: 30
    Posl. poruka: 18.09.2008, 23:18
  3. Prodat Aston Martin
    Od BRABUS u forumu Opšte diskusije o automobilima
    Posl. poruka: 14.03.2007, 22:59
  4. Aston Martin
    Od Sasha u forumu Oldtimeri
    Posl. poruka: 12.01.2005, 12:41
  5. Aston Martin V8 Vantage
    Od dexter u forumu Modeli automobila
    Posl. poruka: 25.10.2004, 17:12
