Rezultati 1 do 9 od 9
Tema: bmw 320d 2001...dimi li dimi...
    12.04.2012
    sremska mitrovica
    juce u toku voznje izgubim gas a na auspuh krene beo dim, tako sekundu ili dve pa prestane pa tako nekoliko puta dok nisam stao. na leru radi sasvim normalno. ugasim pa ga upalim dodam mu gas...prima ga, kao da se nista nije ni desilo. krenem dalje, izadjem na autoput sve ok. posle par minuta opet izgubi gas ali beli dim nisam primetio, vratim se kuci bukvalno na leru. jutros ga upalim, provozam sve je ok, ide sasvim normalno. eto...to je problem mog ljubimca...help
    Corsa, astra, senic
    Odg: bmw 320d 2001...dimi li dimi...
    Posto kazes da je beo dim a motor je jos i naftara proveri najpre nivo rashladne tecnosti.
    White smoke occurs when raw diesel comes through the exhaust completely intact and unburned. Some causes of this include…
    Faulty or damaged injectors
    Incorrect injection timing (could be a worn timing gear or damaged crankshaft keyway).
    Low cylinder compression (eg caused by leaking or broken valves, piston ring sticking, cylinder and/or ring wear, or cylinder glaze)
    When white smoke occurs at cold start, and then disappears as the engine warms up, the most common causes are fouling deposits around piston rings and/or cylinder glazing. Use of our Flushing Oil Concentrate and FTC Decarbonizer address these respective problems.
    Water entering combustion spaces will also create white smoke. Faulty head gaskets and cracked cylinder heads or blocks are a common cause of water entry, and are often to blame. Unfortunately, expensive mechanical repair is the only proper solution here.
    kada totalno ne sagori dizel,takodje bude beo dim. mozda neka dizna radi-ne radi.
    19.03.2012
    zemun
    Fiat Uno 45s fire...
    mozda covek ne zna engleski napisi to na srpskom!!!
    ...ako je model sa VP44 pumpom(a verujem da jeste),lako je moguce da je zaglavio korektor ubrizgavanja u pumpi...
    12.04.2012
    sremska mitrovica
    hvala svima, sutra ce ljubimac na dijagnostiku pa ce se znati nesto vise (nadam se). pozz
    12.04.2012
    sremska mitrovica
    dijagnostika nije prijavila nista oko motora, par stvari (airbag i kabl za brzo grejanje kabine) kasnije sam isao jos dva puta na dijagnostiku i nikad nista nije prijavljeno oko motora. proslo je skoro godinu dana a taj dim mi se nikad vise nije ponovio, motor lepo radi, prima gas, vuce, ne trosi ulje ... eto to je to, nisam imao nista pametno da kazem posle dijagnostike pa se zato nisam ni javljao. pozz
    p.s. ako saznam nesto pametno javim vam
    12.04.2012
    sremska mitrovica
    ljubimac nikad vise nije dimio, nisam nikad vise stiskao gas previse da zadimi i sve tako dok nisam nasao majstora ali ne kao predhodni koji su pricali crklo ovo ono i cifre 200-300 pa navise evra. ovaj majstor je rekao da mu treba malo vise vremena da ga sredi (tri dana) ocistio je neki poveci aluminijumski deo meni kao laiku to deluje kao nekakav usis, unutar tog dela je bilo skoro sve zacepljeno, ocistio i ljubimac od tada ide kao zmaj (nema radara u okolini kojeg nismo overili)
    p.s. majstor je otisao preko tako da je dzaba da ga reklamiram
    23.07.2006
    Opel Vectra B 2.0DI 16v
    Usisna grana najverovatnije...
    Sent from my E2105 using Tapatalk
  1. Dimi ali ne trosi ulje
    Od filipenko u forumu Dizel motori
    Posl. poruka: 31.10.2013, 16:54
  2. Koliko vam dimi vaš dizelaš?
    Od nidza u forumu Lakši tuning
    Odgovora: 26
    Posl. poruka: 07.02.2010, 23:32
  3. dimi ko parnjaca
    Od tmanda323 u forumu Opšte diskusije o automobilima
    Posl. poruka: 18.07.2009, 22:43
  4. Povremeno dimi na leru...
    Od shone190 u forumu Prijemno odeljenje
    Posl. poruka: 29.06.2008, 23:29
  5. Da li je normalno da Tdi dimi?
    Od iwcham1979 u forumu Dizel motori
    Odgovora: 51
    Posl. poruka: 26.06.2008, 01:09
