Strana 98 od 108 PrvaPrva ... 488893949596979899100101102103 ... PoslednjaPoslednja
Rezultati 1.165 do 1.176 od 1292
Tema: Pitanje u vezi izbora ulja
  1. #1165
    Član od
    01.08.2017
    Lokacija
    selo
    Garaža
    Fiat Stilo 1.9 JTD
    A recimo INA Millennium 5W-40 ?
    Sastav iz MSDS
    DeceneHomopolymerHydrogenated 60,0 – 70,0 % m/m EC/CAS 68037-01-4
    Decanoic acid,ester with 2-ethyl-2-(hydroxymethyl)-1,3-propanedioloctanoate 5,0 – 15,0 % m/m EC/CAS 234-392-1/11138-60-6
    Phosphorodithioicacid, mixed O,Obis(1,3-dimethylbutyland iso-Pr)esters,zinc salts <1,7 % m/m EC/CAS 283-392-8/84605-29-8
    Benzenesulfonicacid, mono-C15-36branched alkylderivs., C24 richandOctadecylbenzenesulfonic acid,calciumsalts <0,85 % m/m EC/CAS 274-263-7/ 70024-69-0
    Density at 15 °C, g/cm30,865 ASTM D 4052
    Kinematic viscosity at 100 °C, mm²/s 14,0 ISO 3104
    Viscosity Index 165 ISO 2909
    Dynamic viscosity (CCS), at -30°C, mPas/°C 6 300 ASTM D 5293
    Dynamic viscosity (HTHS), mPas 3,9 CEC L-36-A-90
    Flash point, °C 230 ISO 2592
    Pour point, °C -45 ISO 3016
    Total base number (TBN), mg KOH/g 11,0 ISO 3771
    Sulphated ash, % (m/m) 1,45 ISO 3987
    Foaming, tendency/stability, mL- at 24 °C- at 94 °C- at 24 °C after 94 °C0/010/00/0ISO 6247
    Volatility (Noack), % (m/m) 7,5 CEC L-40-A-93
    Shear stability- kinematic viscosity at 100 C after 30 cycles of shearing, mm2/s 12,8 ASTM D 7109
    Standardi
    ACEA A5/B5-04, A3/B4-04 MB 229.3API SL/CF Volkswagen 502.00/505.00SAE J300 Apr13 BMW Longlife-98INA N 22-250
    http://www.ina-maziva.hr/UserDocsIma...-40_145458.pdf
    http://www.ina-maziva.hr/UserDocsIma...millennium_eng.[1]_103711.pdf
  2. #1166
    Član od
    30.01.2007
    Lokacija
    Neko selo pored Beogr
    Garaža
    Cuore Sportivo 147
    Mnogo mudruješ oko ulja za tako star auto, sipaj bilo šta što odgovara specifikacijama i nećeš pogrešiti
  3. #1167
    Član od
    01.08.2017
    Lokacija
    selo
    Garaža
    Fiat Stilo 1.9 JTD
    Nije to neki benzinac koji će da posrče koji god zejtin da mu sipaš. Nema veze što je star ovaj auto iz cuga prevali put od 2000 km bez potrebe da dolivam kanister ulja i red bi bio da mu sipam kvalitetno ulje. Za preko 50 000 nikad mu nisam dolio ni kap, imam 5x 0,3 l za podmazivanje svega po kući.
    Sileniu sam otkačio jer je precenjena, jeste kvalitetna i ne troši se ali bi ipak na neko pravo sintetičko ulje. Mobil 3000 X1 na koji sam prešao ipak kao i Selenia HC ulje.
  4. #1168
    Član od
    30.01.2007
    Lokacija
    Garaža
    Cuore Sportivo 147
    I ja mislim da je selenia precenjena, zato koristim syntium.
  5. #1169
    Član od
    04.11.2009
    Lokacija
    Bor
    Unosi bloga
    14
    Poštovani g. "Nelson",
    Ako Vam je stalo do prave sintetike a ne HC ulja ("HC Synthese" i slična marketinška njasra), onda je INA koju ste pomenuli dobro rešenje.
    To je ulje na PAO osnovi, jedno od par njih (Ravenol i LM imaju takva, ali ih nije lako naći kod nas) u Evropi.
    Sami ste našli rešenje (uslovno problema).
  6. #1170
    Član od
    15.04.2016
    Lokacija
    okolina Panceva
    Garaža
    Vectra A 1.6SV
    Vectra A '91 (1.6,8V) kada sam je kupio 2011 godine oterao sam je kod majstora (opelov otpad + radionica) da mi promene ulje i kaiseve u stvari sve sto treba.
    Tom prilikom su mi sipali ulje GM 15w/40 i rekli da na 8000km menjam ulje.
    Tako sam i radio sve do sada ali mi sada pade na pamet posto mi je auto na plinu pa ne znam da li bih trebalo da sipam neko drugo ulje mozda neko za gas ili neko drugo?
  7. #1171
    Može, http://www.nisotec.eu/sites/default/...0%2C%20PDS.pdf
    Slično koncipirano ulje imaju i modričina optima i FAM, što su takođe odlična rešenja za taj motor. Btw, optimina slika prikazuje noviju ambalažu a ponegde se isto ulje prodaje i u starijoj varijanti.
  8. #1172
    Član od
    15.04.2016
    Lokacija
    okolina Panceva
    Garaža
    Vectra A 1.6SV
    S obzirom da prelazim malu kilometrazu otprilike jednom godisnje obicno zimi stignem do te kilometraze od 8000km i zamene ulja.
    Da li ima neke razlike ako predjem na ulja za gas u odnosu na "obicno ulje" i da li ostati na istoj gradaciji 15W/40 ili da je menjam?
    Izmenio/la alex1974; 10.11.2017 u 19:16.
  9. #1173
    Član od
    30.01.2007
    Lokacija
    Garaža
    Cuore Sportivo 147
    Ja sam vozio dosta automobila na TNG i nikada nisam koristio ta posebna ulja sto su kao za motore na gas. Uvek gledam koje je odgovarajuce ulje po preporuci fabrike ili eventualno po preporuci majstora ili ako sam procitao na nekom pouzdanom forumu.
  10. #1174
    Član od
    23.03.2005
    Lokacija
    Rooster's Hill , Beog
    Garaža
    Grande Punto 1.2
    ja bi u taj motor ,sipao polusintetiku 10w-40 , neka normalna,dal GM,CAstrol,TOAL,ELF ...,da je orginalno i kvalitetno.
  11. #1175
    Član od
    01.08.2017
    Lokacija
    selo
    Garaža
    Fiat Stilo 1.9 JTD
    Citirati Originalno postavljeno od expendable Pogledati poruku
    None of the above.
    Moj savet Vam je da koristite Ravenol VMO SAE 5W-40.
    0W-40 je verovatno (delom) bazirano na PAO, dok ostala 5W-40 verovatno imaju III+ osnovu.
    VMO ima dobar deo PAO baznih ulja.
    Osim što je "najsintetičkije" 5W-40 ima i dobar paket aditiva (ne baš kao VPD ali blizu).
    VPD je bolji izbor od VST Turbo po tom pitanju iako VST verovatno ima bolju osnovu.
    Ovo Vam je kombinacija (najbolje od oba) ta dva ili možda čak VPD-a i SSL-a (grubo rečeno).
    Osim toga, nivo Fiat odobrenja je najadekvatniji (od sva 4).
    Naravno, i ostala tri dolaze u obzir, po redosledu: VPD, VST, SSL.
    Btw SSL ima ispunjenje standarda najbliže originalnim zahtevima, tako da je redosled uslovan (sa razlikama u nijansama) ili drugačije rečeno: cepidlački.
    Sva su "tu negde" osim VMO koje odskače a da je to primetno.
    Pozdrav!
    Po ovom SDS Ravenol VMO SAE 5W-40 nije PAO osnova ?
    http://elit-oil.io.ua/files/0001/25/00012597.pdf
    ostali MSDS https://elit-oil.io.ua/s944902/dokumentaciya_-_msds
    Koliko su tačni Rusi
    Izmenio/la Nelson; 10.11.2017 u 23:02.
  12. #1176
    Član od
    30.12.2014
    Lokacija
    BL
    Garaža
    Typ 1J
    U SDS-u se navodi samo 70% sastava ulja (prva stavka 60-65%, druga 1-4.9%). Šta je ostatak (30%) - nije navedeno.
Slične teme
  1. Pitanje u vezi TNG
    Od šaki u forumu Domaća vozila
    Odgovora: 1
    Posl. poruka: 10.06.2009, 14:30
  2. pitanje u vezi lpg ecu-a
    Od ninsaki u forumu Sekvencijalni sistemi
    Odgovora: 3
    Posl. poruka: 22.01.2009, 20:18
  3. Pitanje u vezi Woofer-a
    Od Marko_ u forumu Car Audio/Video
    Odgovora: 13
    Posl. poruka: 09.07.2008, 17:13
  4. Pitanje u vezi BRC-a
    Od AlexRS u forumu Sekvencijalni sistemi
    Odgovora: 2
    Posl. poruka: 14.05.2008, 01:02
  5. Pitanje u vezi GPS-a
    Od Skyline GT-R u forumu WasteGate (odušak)
    Odgovora: 2
    Posl. poruka: 16.02.2007, 18:52
Ovlašćenja postavljanja
